Can some tell why robot is drawing 2 assembly-top reinforcements at the same location of the main-top reinforcement. Did I forget a setting ?
Thanks in advance
Solved by Artur.Kosakowski. Go to Solution.
You can either use the settings as shown on the attached picture or just delete the assembly bars from your beam leaving only the top main ones.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
