ARSA Pro 2012 material database error?
2 REPLIES 2
Priitl220
678 Views, 2 Replies
I have regional settings set to "Eurocode".
I have materials: set to Eurocode.
i have default steel set to "S 355"
When I enter new steel section it shows ok. (pic1)
But when i start to enter the bar material is empty. (pic2)
When I try to change wia material , there is no European materials in the list.(pic3)
Any suggestions?
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Tags (1)
2 REPLIES 2
Priitl220
in reply to: Priitl220
It fixed itself after: Changed to other regional settings and material settings. Closed ARSA few times. Changed back to Eurocode. Now it seems to work.
Pawel.Pulak
If the change of regional settings is not related to the change of the language of interface (and automatic restart of Robot) then it is necessary to restart Robot manually to fully reinitialize materials.
Best regards,
Pawel Pulak
Technical Account Specialist
