Discussion Groups
Robot Structural Analysis
Active Contributor
2 Kudos
ARSA 2013 RC required reinforcement errors
563 Views, 6 Replies
11-12-2012 08:41 AM
Dear Sir,
I am using ARSA 2013 SP3 on Win 7 64 bit.
When I try to find the required reinforcement of the RC columns using BAEL 91 or Eurocode the messsage :
"Calculation not performated" is generated as shown in the attachment.
I am missing something?.
Kindly find attached an example about what I am talking about.
Thank you
Product Support
1,305 Kudos
Re: ARSA 2013 RC required reinforcement errors
11-12-2012 08:47 AM in reply to: WASSIMSAID1507
Specify List of Cases for calculations
Rafal Gaweda
Active Contributor
2 Kudos
11-13-2012 01:17 AM in reply to: Rafal.Gaweda
Dear Rafal,
Thank you for your quick reply,
I am Sorry for this mistake, but I intend to show the problem in the calculation of the required reinforcement in more complex structure.
I have a small building designed to resist the seismic forces as per Code PS 92 R 2008....
When I try to calculate the required reinforcement of the RC columns as per RC code  NF EN 1992 1-1/NA-2007 with the adequate Rc parameters, The error message is shown as in the attachment figure.
Kindly find attached the figure & the substructure model showing the Rc columns to be designed.
Your suggestion is very appreciated.
Thank you
Wassim
Product Support
760 Kudos
11-13-2012 03:32 AM in reply to: WASSIMSAID1507
You need to redefine the sections assigned to the columns. They are of RC Beam type whereas they should be the RC Columns ones instead.
Artur Kosakowski
Active Contributor
2 Kudos
11-13-2012 03:58 AM in reply to: Artur.Kosakowski
Thank you Artur,
But I wonder why this was happened since the whole model is imported from the CBS pro and Columns are assigned as RC Column?
Best regards,
Wassim
Product Support
760 Kudos
11-13-2012 04:04 AM in reply to: WASSIMSAID1507
I have just made a quick CBS to Robot export test and as far as I can see the section type is correctly assigned for CBS column in Robot.
Artur Kosakowski
Active Contributor
2 Kudos
11-14-2012 01:32 AM in reply to: Artur.Kosakowski
Thank you Artur for the test,
I will pay more attaention in the future model to know what excatly was happening in exporting the model.
& I will tell you if I will find anything.
Thank you & best regards,
Wassim
