Discussion Groups
Robot Structural Analysis
Active Contributor
WASSIMSAID1507
ARSA 2012- New user section properties-Torsional
173 Views, 2 Replies
12-15-2011 02:16 AM
Dear Sir,
Whren I need to build a new section in the Section definition module, The value of the Torsional moment
Ix=0 (See attachment hereafter).
Saving  the section in the database and using it in the main module,  the software tell me that the torsional property is Zero value!.
How Can I solve the problem?
Thank You
Wassim
Please use plain text.
Product Support
Artur.Kosakowski
Re: ARSA 2012- New user section properties-Torsional
12-15-2011 02:38 AM in reply to: WASSIMSAID1507
The section builder module is not capable of calculating Ix value for composite sections (steel/concrete). You should enter this value manually using the section browser (Tools > section database). The user section database is located in these folders:
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Structural\Common Data\2012\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2012\
Win 7 32- or 64-bit RSAPro:
Artur Kosakowski
Active Contributor
WASSIMSAID1507
12-15-2011 03:04 AM in reply to: Artur.Kosakowski
Thank you so much Artur
