Bonjour,
je souhaite modéliser un voile béton sur appui continu...n'étant pas spécialiste en béton, je n'y arrive pas!!
merci de votre aide,
Benoît
Solved by Rafal.Gaweda. Go to Solution.
Solved by Romanich. Go to Solution.
In english :
I would like to modelize a concrete wall with continuous (linear) support instead of having several node supports.
thanks
benoît
You can apply linear support but for FEM calculations it will be distributed to nodes on such edge.
http://screencast.com/t/iI5KOhT5ZKwN
Ok, but I have'nt the linear support option, only for nodes : problem of update?
Hi, change structure type to shell for example.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
My model is a wood frame, If I create the linear support by changing the type of structure, is it possible to go back in the spatial structure type without loosing any information?
Another questions : how changing the structure type without loosing all my presentation of arrays (desktop model)?
thanks
benoît
What is the current structure type? You can not create Wall panel in Frame Structure type. It must be Shell structure type.
You will not loose any information while changing structure type - you may get only incompatible model with structure type if you change for example shell model with panels to frame model , 3D model onto 2D.
I do not get - change stucture type and check.
