Discussion Groups
Robot Structural Analysis
Active Contributor
0 Kudos
Accepted Solution
Apply Linear Support to Bar
302 Views, 4 Replies
07-10-2012 01:25 AM
Gents,
Is it possible to apply a linear support transveresly to a bar?
I'm trying to model a retaining wall (& including soil interaction) as springs applied along the length of the waler beam.
I'd prefer not to discretise the beam and apply nodal elastic supports.  I'd like to keep a single bar intact.
Cheers.
*Expert Elite* | International Moderator
290 Kudos
Re: Apply Linear Support to Bar
07-10-2012 01:33 AM in reply to: RoboExploiter
have you tried to use Elastic Ground for bars?
Active Contributor
0 Kudos
07-10-2012 01:38 AM in reply to: Romanich
I have considered using this support type, but i'de prefer the versatility of the conventional support definition.  For example I'd really like to be able to fix the longitudinal direction, have springs acting unidirectionally, etc.
290 Kudos
07-10-2012 01:45 AM in reply to: RoboExploiter
To fix the longitudinal direction you can combine Elastic Ground with nodal support, for springs acting unidirectionally - you can use this option:
Product Support
758 Kudos
07-10-2012 01:53 AM in reply to: RoboExploiter
You don't have to divide a bar. It should be enough to define nodes (with supports) along its lenght. In such way you will refer to a single bar number for result's exploration or design.
Artur Kosakowski
