Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Apply Linear Support to Bar
4 REPLIES 4
2167 Views, 4 Replies
Gents,
Is it possible to apply a linear support transveresly to a bar?
I'm trying to model a retaining wall (& including soil interaction) as springs applied along the length of the waler beam.
I'd prefer not to discretise the beam and apply nodal elastic supports.  I'd like to keep a single bar intact.
Cheers.
4 REPLIES 4
Romanich
have you tried to use Elastic Ground for bars?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
in reply to: Romanich
I have considered using this support type, but i'de prefer the versatility of the conventional support definition.  For example I'd really like to be able to fix the longitudinal direction, have springs acting unidirectionally, etc.
Romanich
To fix the longitudinal direction you can combine Elastic Ground with nodal support, for springs acting unidirectionally - you can use this option:
Roman Zhelezniak
Artur.Kosakowski
You don't have to divide a bar. It should be enough to define nodes (with supports) along its lenght. In such way you will refer to a single bar number for result's exploration or design.
Artur Kosakowski
