Hello, I am designing a railway slab which is posed on the deck of a super rigid bridge.
Among all the loads applied, 4 thermal loads are applied to this slab.
1. Uniform variation of temperature +25°C on the whole slab
2. Uniform variation of temperature -25°C on the whole slab.
3. Heat gradient +80°C/m
4. Heat gradient -80°C/m
I would like to know how to fill the definition window of the thermal load for each loading case above. In fact, I have filled this window as follows:
1st case: 2nd case
3rd case: 4th case
I would like to especially know the definition of thermal grandient (case 3 and 4) because these two thermal loading cases are dominating in my project. On knowing that the thickness of my slab is 20 cm, I filled the window with 80 and -80. Is it correct? or it is necessary to fill with a value 80*0.2=16 and (- 80) *0.2=-16 as the heat gradient?
Thank you in advance.
Yan
Solved by Rafal.Gaweda. Go to Solution.
This is correct : value 80*0.2=16 and (- 80) *0.2=-16 as the heat gradient
(in this case you assume initial temp = 0) Full explanation here:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Thermal-Load/td-p/3806569
Case 1 and 2 are correct if you assume initial temp = 0
