Does the API have access to user-defined sections created with the "Section Definition" mode?
I know that once these sections are created the API can access the geometrical properties (area, inertia, etc) of such sections just as any other section, but can the API gain access to the geometry itself (the points and lines that compose the section)?
I don't care about creating such sections through API, just reading their geometry.
Solved by subpartner. Go to Solution.
No, for any section.
Hello
I created a section by user section definer and i want to change default direction of axe y and z. i don't how to do it?
thank you for your help.
Hi @Anonymous
This can be done only at the stage when you are saving the section in the database at the moment you are asked the question about rotating it. If there is no question asked then rotate the section shape in the \section Builder module by 90 degrees and then calculate its properties and save it in the user database.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
thank you for your reply.
There is no message asking me to rotate axes.
I rotate the section 90 degrees but the axes turn too!
the z axis always follows the big inertia of the section!
I work with RSA2010.
Hi @Anonymous,
This feature (rotation of the coordinate system in Section Definition) was implemented in Robot 2017.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
