Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API - Steel member buckling coefficient
1 REPLY 1
systemRobert
657 Views, 1 Reply
/Robert
I really need to change a steel members buckling coefficient with the API.
I got the following VB example from some API documentation:
4.4.2 Addition of Code Settings to a Label of Member Parameters
Dim RdmCodeMembDefPar As Object
Set RdmCodeMembDefPar = RdmMembDefData.CodeParams
With RdmCodeMembDefPar
.BuckLenghtCoeffY = 1#
.BucklingDiagramY = I_DBD_CM66_NO
.BuckLenghtCoeffZ = 0.8
.BucklingDiagramZ = I_DBD_CM66_PINNED_STIFF_0_7
.LoadTypeY = I_DLT_CM66_NO_MID_SPAN_FORCE_LOAD
.LoadTypeZ = I_DLT_CM66_USR_DEF_MOM_MC
.LoadTypeDistY = 2#
.LoadTypeMomMcZ = 26#
.LatBuckType = I_DLBT_CM66_CANTILEVER
.LoadLevel = I_DLL_CM66_UPP_SECT_PAR_LOADED
.LoadLevelValue = 1.2
.LatBuckCoef_LowFlan = I_DLBCD_CM66_USER_DEFINED
.LatBuckCoef_UppFlan = I_DLBCD_CM66_USER_DEFINED
.UserDefLatBuckCoef_LowFlan = 0.7
.UserDefLatBuckCoef_UppFlan = 0.9
.TensAreaNetGros = 1.1
.TubeControl = 1
End With
RdmMembDefData.CodeParams = RdmCodeMembDefPar
But I cant do that in C#! I can't figure out how to cast the generic object to a code parameter object.
Do anyone have an idea of how to do this?
/Robert
1 REPLY 1
Robert,
My assumption is that you managed to change the member length coefficient and now you want to change the buckling length coefficients for SS-EN code using the following code:
IRDimMembParamsEC3 codeData = (IRDimMembParamsEC3)membLabel.Data;
codeData.BuckLengthCoeffY = 0.9;
codeData.BuckLengthCoeffZ = 0.9;
data.CodeParams = codeData;
Please use EC32 instead of EC3 as EC3 refers to the older version of Eurocode 3 whereas the Swedish NAD is based on its newer release.
Artur Kosakowski
