In the thread http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Steel-member-buckling-coefficient/td-p/3... I got to know how to cast the data.codeParams object to a IRDimMembParamsE32. Now im having trouble doing the same with the old swedish code BSK99 (instead of SS-EN 1993-1...).
I've tried casting it to all of these:
IRDimMembParamsANS
IRDimMembParamsBS59
IRDimMembParamsBS59_2000
IRDimMembParamsCB71
IRDimMembParamsCM66
IRDimMembParamsE32
IRDimMembParamsE52
IRDimMembParamsEC3
IRDimMembParamsLRFD
IRDimMembParamsNS34
, but with no luck.
Solved by Artur.Kosakowski. Go to Solution.
Ok.
I cheated a bit and changed to the other code back and forth during member type definitions. I think it works alright, but it's ugly.
