Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API Select Panel Edge
6 REPLIES 6
a54249
679 Views, 6 Replies
Is it possible to select only some edges of a panel and attribute a support to them? For example if i only wanted the Panel 1_EDGE(2) with a "Pinned" support.I was searching for a code similar to the following since this method is fast,
RSelection = str.Selections.Get(IRobotObjectType.I_OT_OBJECT)
RSelection.FromText("All")
RobApp.Project.Structure.Objects.SetLabel(RSelection, IRobotLabelType.I_LT_PANEL_THICKNESS, Esp)
Thanks in advance.
6 REPLIES 6
Rafal.Gaweda
in reply to: a54249
    Dim panel  As RobotObjObject
    Dim edge As RobotObjEdge
    Set panel = RobApp.Project.Structure.Objects.Get(1)
    Set edge = panel.Main.Edges.Get(2)
    edge.SetLabel I_LT_SUPPORT, "Fixed"
    panel.Update
Rafal Gaweda
a54249
in reply to: Rafal.Gaweda
Can't i use something like,
RobApp.Project.Structure.Objects.SetLabel(RSelection, IRobotLabelType.I_LT_EDGE_SUPPORT, "Pinned")
Rafal.Gaweda
in reply to: a54249
You can.
All edges of selected panels will be supported.
Rafal Gaweda
a54249
And i can't select only a single edge?
Like an RSelection.FromText("1_EDGE(1)")?
Rafal.Gaweda
in reply to: a54249
No.
Rafal Gaweda
a54249
Thanks!
