API - Seismic case definition
3 REPLIES 3
con280
597 Views, 3 Replies
Please let me know if it is possible to define a seismic case for EC8 through API and if yes how can be done.
Any help much appreciated.
3 REPLIES 3
Rafal.Gaweda
in reply to: con280
Here it is but unfortunately it does not work for EC code.
We will try to fix it asap.
Dim EC_Params As RobotSeismicAnalysis_EC_8_Params
Dim RCase As RobotSimpleCase
Set RCase = Robapp.Project.Structure.Cases.CreateSimple(Robapp.Project.Structure.Cases.FreeNumber, "Seismic EC", I_CN_SEISMIC, I_CAT_DYNAMIC_SEISMIC)
aaa = RCase.GetSeismicCode ' this is check only line, for EC codes there is no name returned here
'RobotSeismicAnalysis_EC_8_Params refers to ENV 1998-1-1:1994 DAN francaise, which is currently unused - if you are interested I can tell you how to enable this unused code
Set EC_Params = RCase.GetAnalysisParams
EC_Params.BehaviorFactor = 1#
EC_Params.Direction.Set 1, 1, 1
EC_Params.DirectionType = I_SADT_HORIZONTAL
EC_Params.SoilClass = I_SAST_EC_8_SOIL_A
EC_Params.SpectrumType = I_SAST_DIMENSIONING
EC_Params.StructureType = I_SAST_EC_8_B
EC_Params.ZoneType = I_SAZT_EC_8_IA
RCase.SetAnalysisParams EC_Params
Rafal Gaweda
Tags (1)
con280
in reply to: Rafal.Gaweda
Rafal,
Thanks for your response.
From what I understand its impossible to create a seismic case for EC8 through API, but is possible for some of the other seismic codes listed in seismic code database. This is better than nothing.
Thanks.
Rafal.Gaweda
in reply to: con280
For now you are right.
General note:
- set correct code in job preferences
- use RobotSeismicAnalysis_...Params    for this code
the rest of macro should be the same \ similar
Rafal Gaweda
