I would like to define a trapezoidal loading on a bar with RSA API.
Here is the beginning of my script :
Dim CasVent As RobotSimpleCase
Dim LoadRecord As RobotLoadRecord
CasVent = Robot.Project.Structure.Cases.CreateSimple(100, "Vent1", IRobotCaseNature.I_CN_WIND, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
CasVent.Records.New(IRobotLoadRecordType.I_LRT_BAR_TRAPEZOIDALE)
LoadRecord = CasVent.Records.Get(1)
LoadRecord.SetValue ...
I can't find on the API documenation how to define load properties (direction, global/local, value, coordinates,angle,...).
Any idea ? Where can I find this information in the documentation ?
Solved by Rafal.Gaweda. Go to Solution.
