Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API, RSA design
12 REPLIES 12
Message 1 of 13
AbelSV78
1679 Views, 12 Replies
API, RSA design
I have recently started to use API with RSA. I am triying to design a simple steel structure following Robot API SteelDesign help from SDK. I have obtained the bar model but I have not obtained the design bo (see atachment). This is my VBA code:
        robapp.Project.CalcEngine.Calculate()
        Dim RobStr As RobotOM.IRobotStructure
        RobStr = robapp.Project.Structure
        Dim RobLab As RobotOM.IRobotLabel
        Dim RdmMembDefData As RobotOM.IRDimMembDefData
        RobLab = RobStr.Labels.Create(RobotOM.IRobotLabelType.I_LT_MEMBER_TYPE, "barra")
        RdmMembDefData = RobLab.Data
        With RdmMembDefData
            .SetStructureSwayYZ(RobotOM.IRDimMembDefBucklingDataType.I_DMDBDT_BUCKLING_Y, 1)
            .SetLengthYZUV(RobotOM.IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Y, 1.0#)
            .SetStructureSwayYZ(RobotOM.IRDimMembDefBucklingDataType.I_DMDBDT_BUCKLING_Z, 1)
            .SetLengthYZUV(RobotOM.IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Z, 1.0#)
            .SetDeflectionYZ(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, 1)
            .SetDeflectionYZ(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 1)
            .SetDeflYZRelLimit(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, 10.0#)
            .SetDeflYZRelLimit(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 10.0#)
            .CantileverMode = 1
            .SetDisplacementXY(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_X, 1)
            .SetDisplacementXY(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, 1)
            .SetDisplXYRelLimit(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_X, 10.0#)
            .SetDisplXYRelLimit(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, 10.0#)
        End With
        RdmMembDefData.Type = RobotOM.IRDimMembDefType.I_DMDT_USER
        'robapp.Structure.Labels.Store(Lab)
        'GENERAR GRUPOS
        RDmServer = robapp.Kernel.GetExtension("RDimServer")
        RDmServer.Mode = RobotOM.IRDimServerMode.I_DSM_STEEL
        RDmGrps = RDmServer.GroupsService
        GroupNo = 1
        RDmGrpl = RDmGrps.[New](0, GroupNo)
        RDmGrpl.Material = "S 275"
        RDmGrpl.Name = "grupo1"
        RDmStream = RDmServer.Connection.GetStream
        RDmStream.Clear()
        RDmStream.WriteText("1 3")
        RDmGrpl.SetMembList(RDmStream)
        RDmGrpProfs = RDmServer.Connection.GetGrpProfs
        RDmGrpProfs.Clear()
        RDmStream.Clear()
        'RDmStream.WriteText("IPE")
        'RDmGrpProfs.SetFamilies("Rcat", RDmStream)
        RDmGrpl.SetProfs(RDmGrpProfs)
        RDmGrps.Save(RDmGrpl)
        'PREPARAR DIMENSIONAMIENTO
        RDmEngine = RDmServer.CalculEngine
        With RDmEngine
            RDmCalPar = .GetCalcParam
            RDmCalCnf = .GetCalcConf
        End With
        RDmStream.Clear()
        RDmCalCnf.SetParamValue(RobotOM.IRDimCalcConfValueType.I_DCCPV_EFFRATIO, 0.9)
        RDmStream.WriteText("todo")
        RDmCalPar.SetObjsList(RobotOM.IRDimCalcParamVerifType.I_DCPVT_GROUPS_DESIGN, RDmStream)
        RDmCalPar.SetLimitState(RobotOM.IRDimCalcParamLimitStateType.I_DCPLST_SERVICEABILITY, 1)
        RDmCalPar.SetLimitState(RobotOM.IRDimCalcParamLimitStateType.I_DCPLST_ULTIMATE, 1)
        RDmStream.Clear()
        RDmStream.WriteText("1 2")
        RDmCalPar.SetLoadsList(RDmStream)
        RDmOptPar = RDmCalPar.GetOptimParam
        RDmOptPar.Optimization = 1
        RDmOptPar.SetOption(RobotOM.IRDimOptimParamOptionType.I_DOPOT_WEIGHT, 1)
        RDmOptPar.SetOption(RobotOM.IRDimOptimParamOptionType.I_DOPOT_MAX_SECTION_HEIGHT, 1)
        RDmOptPar.SetLimit(RobotOM.IRDimOptimParamLimitType.I_DOPLT_MAX_SECTION_HEIGHT, 0.5)
        RDmOptPar.SetOption(RobotOM.IRDimOptimParamOptionType.I_DOPOT_MIN_SECTION_HEIGHT, 1)
        RDmOptPar.SetLimit(RobotOM.IRDimOptimParamLimitType.I_DOPLT_MIN_SECTION_HEIGHT, 0.1)
        RDmOptPar.SetOption(RobotOM.IRDimOptimParamOptionType.I_DOPOT_MIN_FLANGE_THICKNESS, 1)
        RDmOptPar.SetLimit(RobotOM.IRDimOptimParamLimitType.I_DOPLT_MIN_FLANGE_THICKNESS, 0.01)
        RDmOptPar.SetOption(RobotOM.IRDimOptimParamOptionType.I_DOPOT_MIN_WEB_THICKNESS, 1)
        RDmOptPar.SetLimit(RobotOM.IRDimOptimParamLimitType.I_DOPLT_MIN_WEB_THICKNESS, 0.05)
        RDmOptPar.SetOption(RobotOM.IRDimOptimParamOptionType.I_DOPOT_ENTIRE_SET_SECTIONS, 1)
        RDmCalPar.SetOptimParam(RDmOptPar)
        With RDmEngine
            RDmEngine.SetCalcConf(RDmCalCnf)
            RDmEngine.SetCalcParam(RDmCalPar)
        End With
        'DIMENSIONAMIENTO
        RDmEngine.Solve(Nothing)
        RdmAllRes = RDmEngine.Results
        RdmAllResObjType = RdmAllRes.ObjectsType
        ObjCnt = RdmAllRes.ObjectsCount
        RDmGrpRes = RdmAllRes.Get(1)
        PrfFamCnt = RDmGrpRes.FamiliesCount
        Dim Index As Long
        For Index = 0 To PrfFamCnt - 1
            If Index = 0 And RDmGrpRes.IsOptimization Then
                OptFamIndex = RDmGrpRes.OptFamilyIndex
            If RDmGrpRes.Check(Index, RobotOM.IRDimGrpResCurrProf.I_DGRCP_PREVIOUS) Then
                RdmDetRes = RDmGrpRes.Get(Index, RobotOM.IRDimGrpResCurrProf.I_DGRCP_PREVIOUS)
            If RDmGrpRes.Check(Index, RobotOM.IRDimGrpResCurrProf.I_DGRCP_GOVERNING) Then
                RdmDetRes = RDmGrpRes.Get(Index, RobotOM.IRDimGrpResCurrProf.I_DGRCP_GOVERNING)
            If RDmGrpRes.IsOptimization And Index = OptFamIndex Then
                'section is optimal
            If RDmGrpRes.Check(Index, RobotOM.IRDimGrpResCurrProf.I_DGRCP_NEXT) Then
                RdmDetRes = RDmGrpRes.Get(Index, RobotOM.IRDimGrpResCurrProf.I_DGRCP_NEXT)
        Next
        'FINALIZAR EL CODIGO
        robapp.Window.Activate()
        rec = Nothing
        cas = Nothing
        node = Nothing
        sup_data = Nothing
        sup = Nothing
        s = Nothing
        robapp = Nothing
    End Sub
End Class
Could you help me in order to finish the steel design?
Is there any help document a little bit detailed?
Thank you in advance, best regards
12 REPLIES 12
Message 2 of 13
Rafal.Gaweda
in reply to: AbelSV78
Message 3 of 13
AbelSV78
Thank you very much for your attention. What we are looking for is the optimal section for the profiles of a structure, is it possible?
Best regards
Message 5 of 13
AbelSV78
in reply to: Rafal.Gaweda
Thank you again, but I was loofing for "change" or "Change all" sollution, and I have seen that it is not implemented in Robot API.
Is it correct??
Best regards.
Message 6 of 13
Rafal.Gaweda
Rafal Gaweda
Message 7 of 13
AbelSV78
Thanks a lot. this is what I was looking for.
I am preparing a recursive process, is there any way in order to avoid the "Acept" window in Robot after "change all"?
Thank you again...
Message 8 of 13
Rafal.Gaweda
What about robapp.Interactive=false?
Rafal Gaweda
Message 9 of 13
How can I define load duration class for Eurocode 5 timber design (with RobotOM API)
I join a picture to illustrate what I want to set by coding in VB.NET
Cordialement,
Charles THIERRY DE VILLE D'AVRAY
villedavray_charles@yahoo.fr
Best Regards,
Message 10 of 13
How can I define a Parameterizable section by coding with RObot API (Just like the following picture) ?
Best Regards,
Message 11 of 13
'I find only the way to diplay the dialog box that allows you to define the duration of loads :
Dim RdmConnection As robotom.IRDimConnection = RDmServer.Connection
Dim Obj As Object = Nothing
RdmConnection.SendMessage(IRDimconnectionMsg.I_DCM_SHOW_LOADCASES_DIALOG, Obj)
Best Regards,
Message 12 of 13
Not implemented
Rafal Gaweda
Message 13 of 13
Not implemented.
Rafal Gaweda
