I created an algorithm that constantly changes the geometry of a structure in robot and because of that I constantly get the following message,
"The performed operation will cause the changes in the database containing structure data and may cause a change of the result status to 'not available' do you want to continue?"
Is there any way of always say "Yes" by default?
Thanks in advance
Solved by Rafal.Gaweda. Go to Solution.
