(API) Robot API - Selection by attributes.
3 REPLIES 3
V_Andres
690 Views, 3 Replies
Hello all,
I would like to know if Robot API allows you to do the same type of special selection by attributes as the GUI does.
I have been reading through the API User Guide, but I cannot find how to do the following:
- Given a node
- Select the finite elements associated with that node
- Select the panels associated with those finite elements
Through the GUI it would be:
Thanks!
V.
3 REPLIES 3
Rafal.Gaweda
in reply to: V_Andres
Of course it can be done - of course by your own 🙂
As you remember I wrote you example code how to select \ check to which panel node belongs
http://forums.autodesk.com/t5/robot-structural-analysis/robot-api-compatibility-between-robot-2014-a...
Create in similar way other selections you want
Rafal Gaweda
V_Andres
in reply to: Rafal.Gaweda
Thank you Rafal,
I just wanted to made sure that there wasn't a direct method to do it.
I have done it as per your script, but I have many nodes and panels so I was hoping to find a way to increase speed (currently it takes 3 hours to run the script).
Cheers,
V.
Rafal.Gaweda
Hope you are comparing selections, not using too many loops
Rafal Gaweda
