Hello all,
I would like to know if Robot API allows you to do the same type of special selection by attributes as the GUI does.
I have been reading through the API User Guide, but I cannot find how to do the following:
- Given a node
- Select the finite elements associated with that node
- Select the panels associated with those finite elements
Through the GUI it would be:
Thanks!
V.
Solved by Rafal.Gaweda. Go to Solution.
Of course it can be done - of course by your own 🙂
As you remember I wrote you example code how to select \ check to which panel node belongs
Create in similar way other selections you want
Thank you Rafal,
I just wanted to made sure that there wasn't a direct method to do it.
I have done it as per your script, but I have many nodes and panels so I was hoping to find a way to increase speed (currently it takes 3 hours to run the script).
Cheers,
V.
