Hi.
I've been developing an API on which it is supposed to set the coordinates new coordinates for a modelpoint. I tried doing so thorught the folowing code:
Dim Robot as new Robotapplication
Dim panel as IRobotObjObject
Dim model_point_3d As IRobotGeoPoint3D
panel = Robot.Project.Structure.Objects.Get(1)
model_point_3d = panel.Main.Modelpoints.Get(3)
model_point_3d.Set(50, 50, 50)
The code actually runs but it has no effect and also returns no errors. I've also tried checking the modelpoint coordinates after running the "Set" command, and it actually returns "50,50,50" but once again it has no effect in the Robot interface, even after refreshing the viewport. Is there any workaround for this?
Thnaks in advance
