Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) macro for nodal displacements in local coordinate system of bars
3 REPLIES 3
Rafal.Gaweda
2058 Views, 3 Replies
- it works on bars selection made in Robot
- it works for simple cases and manual combinations
- calculation nodes are considered for results presentation
Rafal Gaweda
3 REPLIES 3
jrandeep
in reply to: Rafal.Gaweda
I am new to this macro thing.
When I do run the macro for nodal displacements in local coordinate system of bars.
It gives me a warning "Open Robot and Load Model",
Could you please explain the procedure how to use this excel sheet.
Thanks.
BR,
J,Randeep
Rafal.Gaweda
in reply to: jrandeep
Do you use W8 or W8.1 system ?
Rafal Gaweda
Rafal.Gaweda
Try
Go to VBA Editor (Alt+F11), go to References, unmark Robot Object Modeler, close References window by pressing OK, open it again, select  Robot Object Modeler (ver. 14.0. for ARSA 2014), press OK
User-added image
If it does not help
1. Run Excel as Administrator, run Robot as Administrator, then check macro
2. Check \ set UAC :
User-added image
If it does not help
unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
eg, type such commands in Command Prompt window started in Administrator mode:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\robot.EXE" /unRegServer
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2014\System\Exe\robot.EXE" /unRegServer
then
register the one you want to use.
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2014\System\Exe\robot.EXE" /RegServer
Rafal Gaweda
