(API) macro for nodal displacements in local coordinate system of bars
3 REPLIES 3
Rafal.Gaweda
2068 Views, 3 Replies
- it works on bars selection made in Robot
- it works for simple cases and manual combinations
- calculation nodes are considered for results presentation
Rafal Gaweda
3 REPLIES 3
in reply to: Rafal.Gaweda
I am new to this macro thing.
When I do run the macro for nodal displacements in local coordinate system of bars.
It gives me a warning "Open Robot and Load Model",
Could you please explain the procedure how to use this excel sheet.
Thanks.
BR,
J,Randeep
Rafal.Gaweda
Do you use W8 or W8.1 system ?
Rafal Gaweda
Rafal.Gaweda
Try
Go to VBA Editor (Alt+F11), go to References, unmark Robot Object Modeler, close References window by pressing OK, open it again, select  Robot Object Modeler (ver. 14.0. for ARSA 2014), press OK
User-added image
If it does not help
1. Run Excel as Administrator, run Robot as Administrator, then check macro
2. Check \ set UAC :
User-added image
If it does not help
unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
eg, type such commands in Command Prompt window started in Administrator mode:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\robot.EXE" /unRegServer
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2014\System\Exe\robot.EXE" /unRegServer
then
register the one you want to use.
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2014\System\Exe\robot.EXE" /RegServer
Rafal Gaweda
