Macro for creating superbars \ supermembers in Excel table
See attached file
Solved by t.sautierr. Go to Solution.
Hi Rafal,
This api seems very nice (as usual on your creations).
Is there a chance to import superbar from robot to edit them, and also read "Available Bar Types" on model? Almost like you did on api to create and edit load cases and combinations.
If you could to this mods they will be very useful.
RR
Is it supposed to also work with superbars created from trapezoidal loading??
I´m getting an error
Rafael Medeiros
Probably there is no MEMBER_TYPE label for this superbar. You may add If RBar.HasLabel(I_LT_MEMBER_TYPE) Then ... End If
No API skills here
thx anyway!
Rafael Medeiros
