Message 1 of 21
(API) Inaccurate results using the extreme results server
08:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I'm currently trying to get the maximum principal stress on two finite elements panelsl from Excel with VBA. I'm getting the results with robApp.Project.Structure.Results.FiniteElems.MaxValue(extParams).Value and I'm feeding it withfollowing parameters extParams.ElementSel = objPanel.FiniteElems 'Where objPanel is the corresponding RobotObjObject extParams.CaseSel = CStr(loadCase) extParams.Smoothing = I_FRS_NO_SMOOTHING extParams.resultID = valType 'Here, this is equal to I_FRT_PRINCIPAL_S1 extParams.Layer = I_FLT_UPPER 'I'd have the maximal, minimal or absolute max but the values doesn't seem available... Each time I call this function I get the same results as displayed in RSA for the first panel but the results for the second one are almost always wrong (eg I get 16 Mpa in excel for 3 Mpa displayed in RSA). I noticed that I could get the same results in Excel as in RSA if I close RSA and reopen the model, then call the function from excel without having run the model again. Do you know where this problem comes from ? PS : I posted in another topic about the method using the query mechanism but I got an error 429 and I read it might be even longer to run. To the admin team, I had problems seeing the topic list inside the board page and posting with firefox and IE. Now I can post using Chrome but still no topics appear in the board page. Thanks, Regards.
