(API) How can I get a homogeneous Finite Element thickness
6 REPLIES 6
1246 Views, 6 Replies
Hi Rafal,
How can I get a homogeneous Finite Element thickness by Robot API?
6 REPLIES 6
Rafal.Gaweda
Example how you create such label also with kz:
    thick_name = "Panel th with KZ"
    Dim Label As RobotLabel
    Set Label = robapp.Project.Structure.Labels.Create(I_LT_PANEL_THICKNESS, thick_name)
    Dim ThickData As RobotThicknessData
    Set ThickData = Label.Data
    ThickData.ElasticFoundation = 10000
    ThickData.ThicknessType = I_TT_HOMOGENEOUS
    ThickData.MaterialName = material_name
    Dim HomoThickData As RobotThicknessHomoData
    Set HomoThickData = ThickData.Data
    HomoThickData.Type = I_THT_CONSTANT
    HomoThickData.ThickConst = 0.3
    robapp.Project.Structure.Labels.Store Label
Rafal Gaweda
in reply to: Rafal.Gaweda
I'm doing a little program in C# to analyze slabs according MCFT (Modified Compression Field Theory). One of the parameters that I need to now is finite elements thickness. This program analyse all finite elements select and for each one I need to get thickness and membrane stress. I dont know how to obtain finite elements thickness in my robot model by API.
Could you help me?
Rafal.Gaweda
Understood now.
I will check.
Rafal Gaweda
Rafal.Gaweda
If it is homogenous thickness you do not need to get it for each FE (in fact you can get panel th label assigned to each FE).
Take it from panel - faster = once per panel
Example code for every Fe
Dim RSelection As RobotSelection
    Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_PANEL)
    Dim PanelCol As RobotObjObjectCollection
    Set PanelCol = RobApp.Project.Structure.Objects.GetMany(RSelection)
    For ii = 1 To PanelCol.Count
        Dim obj As RobotObjObject
        Set obj = RobApp.Project.Structure.Objects.Get(PanelCol.Get(ii).Number)
        Dim FEs As String
        FEs = obj.FiniteElems
        Set RSelection = RobApp.Project.Structure.Selections.Create(I_OT_FINITE_ELEMENT)
        RSelection.FromText (FEs)
        Dim FECollection As RobotFiniteElementCollection
        Dim FE As RobotFiniteElement
        Set FECollection = RobApp.Project.Structure.FiniteElems.GetMany(RSelection)
        Dim THLabel As RobotLabel
        Dim THData As RobotThicknessData
        For i = 1 To FECollection.Count
            Set FE = FECollection.Get(i)
            If FE.FeType = I_FET_T3 Or I_FET_Q4 Then
                Cells(12 + i, 3) = FE.Number
                Set THLabel = FE.GetLabel(I_LT_PANEL_THICKNESS)
                Set THData = THLabel.Data
                If THData.ThicknessType = I_TT_HOMOGENEOUS Then
                    Set HomoThickData = THData.Data
                    Cells(12 + i, 4) = HomoThickData.ThickConst
                End If
            End If
        Next i
    Next ii
Rafal Gaweda
Rafal,
You are unbelievable,
It works perfectly.
Thank you very much.
I am using Robot SDK 2021 version:
The output of .Get(_) below is not RobotObjObject but RobotDataObject.
Can you please help me how to get the output as datatype RobotObjObject.
i am create contours in my project.
Dim obj As RobotObjObject Set obj = RobApp.Project.Structure.Objects.Get(PanelCol.Get(ii).Number)
