Discussion Groups
Robot Structural Analysis
Product Support
1,303 Kudos
Re: API Help - Bar lenght and Other
10-19-2012 03:44 AM in reply to: FilRib
What should i do to extract data only for 1 point?
I want data (forces, section propreties, etc...) for the point x=0 of the bar.
Small modifications and we have a new macro ... attached
Rafal Gaweda
Valued Contributor
0 Kudos
10-19-2012 03:45 AM in reply to: FilRib
Hi again,
Other question?
The current output is organized by nodes, i.e:
BarraCaso
15317
15417
15318
15418
15319
15419
15320
15420
What should i do to have this output:
BarraCaso
15317
15318
15319
15320
15417
15418
15419
15420
Thanks!
Product Support
1,303 Kudos
10-19-2012 03:48 AM in reply to: athurD
ROBOT_GOOD wrote:
hi.
File excel erro ???????
Macros from this thread do not work with selections made  in robot.
Fill correct data in Excel cells or modify macro.
Rafal Gaweda
Product Support
1,303 Kudos
10-19-2012 03:55 AM in reply to: FilRib
Barra Caso
1 53 17
1 54 17
Barra Caso
1 53 17
1 53 18
Just one loop should be changed ... file in message 19, below
Rafal Gaweda
Valued Contributor
0 Kudos
10-19-2012 04:02 AM in reply to: Rafal.Gaweda
You are THE MAN! :smileyhappy:
Very Very Useful !
Valued Contributor
0 Kudos
10-19-2012 04:28 AM in reply to: FilRib
Hi Rafal, i tested this last file you sent to user FilRib and something is not ok....because that macro puts forces on end node equal to origin node.
Product Support
1,303 Kudos
10-19-2012 04:40 AM in reply to: RRufino
Yep, my mistake.
Rafal Gaweda
Valued Contributor
0 Kudos
10-19-2012 06:20 AM in reply to: Rafal.Gaweda
I think that the successive adaption turned the process too messy.
I tried this one and i found that for origin nodes some values are not ok (example: My and Mz), on the other hand if you have more then one combination, forces for end node still remains equal to origin node.
Or am i seeing this wrong?
Product Support
1,303 Kudos
10-19-2012 06:44 AM in reply to: RRufino
No, you are right. To many modifications.
Check this one.
Rafal Gaweda
