Discussion Groups
Robot Structural Analysis
Valued Contributor
0 Kudos
API Help - Bar lenght and Other
336 Views, 18 Replies
10-18-2012 04:28 AM
Hi all,
I was trying to adapt some macros that some users gently post here on Discussion Groups.
I already made a part of what i wanted...but this is the first time i'm trying to use macros, so i'm not being able to do the rest.
I have already a way to have all forces on my xls file, but i want to get in the following columns Lenght(m) | Section | Rect_BF | Rect_HT | Rect_EP | Bar Name | Deflection (mm)
How can i do this? Can you help me?
Thanks, please see attachement
Product Support
1,305 Kudos
Re: API Help - Bar lenght and Other
10-18-2012 04:39 AM in reply to: RRufino
Example code:
The sectional data \ interface \ access depends of section type: from database or user or tappered or complex ....
What sections do you have?
Dim RobApp As New RobotApplication
Dim Bar As IRobotBar
Dim Sel As IRobotSelection
Dim Sec As RobotBarSection
Dim BarCol As RobotBarCollection
Dim sectData As IRobotBarSectionData
Set Sel = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
Set BarCol = RobApp.Project.Structure.Bars.GetMany(Sel)
For i = 1 To BarCol.Count
    Set Bar = BarCol.Get(i)
    Set sectLab = Bar.GetLabel(I_LT_BAR_SECTION)
    Set sectData = sectLab.Data
    Set Sec = Bar.GetLabel(I_LT_BAR_SECTION)
    Cells((7 + i), 1) = Bar.Number
    Cells((7 + i), 2) = Bar.Length
    Cells((7 + i), 3) = Sec.Name
    Cells((7 + i), 4) = sectData.GetValue(I_BSDV_AX) ' A of section
    Cells((7 + i), 5) = sectData.GetValue(I_BSDV_D) ' h of section
Next i
Exit Sub
Rafal Gaweda
Valued Contributor
0 Kudos
10-18-2012 04:57 AM in reply to: Rafal.Gaweda
I have regular Rc Beams and Rc Columns.
I tried to copy that code to "my" macros but it simply not work...where should i paste that?
Thanks in advance
Product Support
1,305 Kudos
10-18-2012 05:01 AM in reply to: RRufino
OK , I will show you.
It was example for steel sections - copy it to separate xls file
Rafal Gaweda
Valued Contributor
0 Kudos
10-18-2012 05:48 AM in reply to: Rafal.Gaweda
Thanks Rafal, if you don't mind please check the attachement on my first post.
Product Support
1,305 Kudos
10-19-2012 01:25 AM in reply to: RRufino
Take a look at attached xls
Rafal Gaweda
Valued Contributor
0 Kudos
10-19-2012 02:22 AM in reply to: RRufino
Dear Rafal, i don't know how to thank you!
Thank you so much!
Greetings from Portugal!
1000 kudos for you!
Valued Contributor
0 Kudos
10-19-2012 02:47 AM in reply to: RRufino
Hi Rafal,
I'm seeing that this macro is for 2 or more points in a bar.
What should i do to extract data only for 1 point?
For example:
I want data (forces, section propreties, etc...) for the point x=0 of the bar.
Thanks in advance,
Cheers!
Distinguished Contributor
2 Kudos
10-19-2012 03:39 AM in reply to: FilRib
hi.
File excel erro ???????
Valued Contributor
0 Kudos
10-19-2012 03:42 AM in reply to: athurD
Where is the error?
