API Help - Bar lenght and Other
18 REPLIES 18
Message 1 of 19
RRufino
721 Views, 18 Replies
Hi all,
I was trying to adapt some macros that some users gently post here on Discussion Groups.
I already made a part of what i wanted...but this is the first time i'm trying to use macros, so i'm not being able to do the rest.
I have already a way to have all forces on my xls file, but i want to get in the following columns Lenght(m) | Section | Rect_BF | Rect_HT | Rect_EP | Bar Name | Deflection (mm)
How can i do this? Can you help me?
Thanks, please see attachement
18 REPLIES 18
Message 2 of 19
Rafal.Gaweda
in reply to: RRufino
Example code:
The sectional data \ interface \ access depends of section type: from database or user or tappered or complex ....
What sections do you have?
Dim RobApp As New RobotApplication
Dim Bar As IRobotBar
Dim Sel As IRobotSelection
Dim Sec As RobotBarSection
Dim BarCol As RobotBarCollection
Dim sectData As IRobotBarSectionData
Set Sel = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
Set BarCol = RobApp.Project.Structure.Bars.GetMany(Sel)
For i = 1 To BarCol.Count
    Set Bar = BarCol.Get(i)
    Set sectLab = Bar.GetLabel(I_LT_BAR_SECTION)
    Set sectData = sectLab.Data
    Set Sec = Bar.GetLabel(I_LT_BAR_SECTION)
    Cells((7 + i), 1) = Bar.Number
    Cells((7 + i), 2) = Bar.Length
    Cells((7 + i), 3) = Sec.Name
    Cells((7 + i), 4) = sectData.GetValue(I_BSDV_AX) ' A of section
    Cells((7 + i), 5) = sectData.GetValue(I_BSDV_D) ' h of section
Next i
Exit Sub
Rafal Gaweda
Message 3 of 19
RRufino
in reply to: Rafal.Gaweda
I have regular Rc Beams and Rc Columns.
I tried to copy that code to "my" macros but it simply not work...where should i paste that?
Thanks in advance
Message 4 of 19
Rafal.Gaweda
OK , I will show you.
It was example for steel sections - copy it to separate xls file
Rafal Gaweda
Message 5 of 19
RRufino
Thanks Rafal, if you don't mind please check the attachement on my first post.
Message 6 of 19
Rafal.Gaweda
Take a look at attached xls
Rafal Gaweda
Message 7 of 19
RRufino
Dear Rafal, i don't know how to thank you!
Thank you so much!
Greetings from Portugal!
1000 kudos for you!
Message 8 of 19
FilRib
Hi Rafal,
I'm seeing that this macro is for 2 or more points in a bar.
What should i do to extract data only for 1 point?
For example:
I want data (forces, section propreties, etc...) for the point x=0 of the bar.
Thanks in advance,
Cheers!
Message 9 of 19
athurD
in reply to: FilRib
hi.
File excel erro ???????
Message 10 of 19
FilRib
in reply to: athurD
Where is the error?
Message 11 of 19
Rafal.Gaweda
in reply to: FilRib
Small modifications and we have a new macro ... attached
Rafal Gaweda
Message 12 of 19
FilRib
in reply to: FilRib
Hi again,
Other question?
The current output is organized by nodes, i.e:
BarraCaso
15317
15417
15318
15418
15319
15419
15320
15420
What should i do to have this output:
BarraCaso
15317
15318
15319
15320
15417
15418
15419
15420
Thanks!
Message 13 of 19
Rafal.Gaweda
in reply to: athurD
@Robot_GOOD wrote:
hi.
Macros from this thread do not work with selections made  in robot.
Fill correct data in Excel cells or modify macro.
Rafal Gaweda
Message 14 of 19
Rafal.Gaweda
in reply to: FilRib
Barra Caso
1 53 17
1 54 17
Barra Caso
1 53 17
1 53 18
Just one loop should be changed ... file in message 19, below
Rafal Gaweda
Message 15 of 19
FilRib
You are THE MAN! 🙂
Very Very Useful !
Message 16 of 19
RRufino
in reply to: FilRib
Hi Rafal, i tested this last file you sent to user FilRib and something is not ok....because that macro puts forces on end node equal to origin node.
Message 17 of 19
Rafal.Gaweda
Yep, my mistake.
Rafal Gaweda
Message 18 of 19
RRufino
I think that the successive adaption turned the process too messy.
I tried this one and i found that for origin nodes some values are not ok (example: My and Mz), on the other hand if you have more then one combination, forces for end node still remains equal to origin node.
Or am i seeing this wrong?
Message 19 of 19
Rafal.Gaweda
No, you are right. To many modifications.
Check this one.
Rafal Gaweda
