I am trying to create code combinations for Robot from VB.net. I am using this:
engine = robapp.Project.Structure.Cases.CodeCmbEngine
engine.Params.SelectCombinationType(RobotOM.IRobotCombinationType.I_CBT_ULS, True)
engine.Generate()
but it doesn't work. Perhaps I need to define params, but I don't know the variables and how to use it. Could you help me?
Thank you so much in advance
Solved by AbelSV78. Go to Solution.
Dim r As New RobotOM.RobotApplication Dim q As RobotOM.RobotCodeCombinationEngine q = r.Project.Structure.Cases.CodeCmbEngine q.Params.GenType = RobotOM.IRobotCodeCmbGenerationType.I_CCGT_FULL q.Params.SelectCombinationType RobotOM.IRobotCombinationType.I_CBT_ULS, True q.Params.SelectCombinationType RobotOM.IRobotCombinationType.I_CBT_SLS, True q.Generate
Thank you so much, but there is another problem:
"Incorrect definition of relations between case groups".
I have used different simple cases of different nature. I know the problem in Robot, but I don't know how to solve with API.
Regards
Old example below, something may not work but at least it should give you idea how to play with it
(do not use Kernel in your code ; just example)
Public Sub CodeCombinations(ByVal ccE As RobotOM.RobotCodeCombinationEngine, ByVal k As KernelOM.RobotKernel) Dim KccE As KernelOM.RobotCodeCombinationEngine KccE = k.Structure.Cases.CodeCmbEngine 'Dim ccG As RobotOM.RobotCodeCmbGroup 'Dim KccG As KernelOM.RobotCodeCmbGroup Dim cas_lst As String = "" Const COMB_TYPES As Integer = 7 'Const COMB_GROUPS As Integer = 6 Const COMB_DECID_VAL As Integer = 14 'Const COEF_COUNT As Integer = 13 Dim i As Integer 'Dim j As Integer Dim q As Integer KccE.Params.GenType = ccE.Params.GenType 'cases Dim casCol As RobotOM.IRobotCollection Dim KcasCol As KernelOM.IRobotCollection casCol = ccE.Params.ActiveCases KcasCol = KccE.Params.ActiveCases Dim cinfo As RobotOM.RobotCodeCmbActiveCaseInfo Dim Kcinfo As KernelOM.RobotCodeCmbActiveCaseInfo For i = 1 To KcasCol.Count Kcinfo = KcasCol.Get(i) For q = 1 To casCol.Count cinfo = casCol.Get(q) If cinfo.CaseNumber = Kcinfo.CaseNumber Then Exit For End If Next If cinfo.IsSelected Then Kcinfo = KcasCol.Get(i) Kcinfo.IsSelected = cinfo.IsSelected Kcinfo.Coefficient = cinfo.Coefficient End If Next If ccE.Params.AllBars Then KccE.Params.AllBars = ccE.Params.AllBars Else KccE.Params.BarSel = ccE.Params.BarSel End If If ccE.Params.AllNodes Then KccE.Params.AllNodes = ccE.Params.AllNodes Else KccE.Params.NodeSel = ccE.Params.NodeSel End If KccE.Params.ExtremalSnowFactor = ccE.Params.ExtremalSnowFactor If KccE.Params.GenType = KernelOM.IRobotCodeCmbGenerationType.I_CCGT_SIMPLIFIED Then For i = 1 To COMB_DECID_VAL KccE.Params.SelectDecidingValue(i, ccE.Params.IsDecidingValueSelected(i)) Next KccE.Params.SelectDecidingValue(KernelOM.IRobotCodeCmbDecidingValueType.I_CCDVT_REACTIONS, _ ccE.Params.IsDecidingValueSelected(RobotOM.IRobotCodeCmbDecidingValueType.I_CCDVT_REACTIONS)) End If 'For q = 1 To ccE.Params.Regulations.Actions.Count ' KccE.Params.Regulations.Actions.SetNature(q, ccE.Params.Regulations.Actions.GetNature(q)) ' KccE.Params.Regulations.Actions.SetName(q, ccE.Params.Regulations.Actions.GetName(q)) ' For j = 0 To COEF_COUNT ' KccE.Params.Regulations.Actions.SetCoeff(q, j, ccE.Params.Regulations.Actions.GetCoeff(q, j)) ' Next 'Next 'Dim lim_state As RobotOM.IRobotLimitState 'Dim cmb_typ As RobotOM.IRobotCodeCmbCombType 'Dim cmb_nam As String = "" 'Dim d_c As Short, l_c As Short, a_c As Short, s_c As Short 'For i = 1 To ccE.Params.Regulations.Combinations.Count ' ccE.Params.Regulations.Combinations.Get(i, lim_state, cmb_typ, cmb_nam, d_c, l_c, a_c, s_c) ' KccE.Params.Regulations.Combinations.[New](lim_state, cmb_typ, cmb_nam, d_c, l_c, a_c, s_c) 'Next 'Try ' q = 0 ' While True ' KccE.Params.SelectCombination(q, ccE.Params.IsCombinationSelected(q)) ' q += 1 ' End While 'Catch ex As Exception ' 'end of combinations 'End Try 'combinations For i = 0 To COMB_TYPES If ccE.Params.IsCombinationTypeSelected(i) Then KccE.Params.SelectCombinationType(i, True) Else KccE.Params.SelectCombinationType(i, False) End If Next 'groups 'For i = 0 To COMB_GROUPS ' For j = 0 To ccE.Params.Groups.GetCount(i) ' ccG = ccE.Params.Groups.Get(i, j) ' For q = 1 To ccG.CaseCount ' If ccG.IsFull Then ' 'KccG.AddAll() ' End If ' Next ' KccE.Params.Groups.[New](i, ccG.Operator, cas_lst) ' cas_lst = "" ' Next 'Next 'relations 'Dim crel As RobotOM.RobotCodeCmbGroupRelation 'Dim Kcrel As KernelOM.RobotCodeCmbGroupRelation 'For q = 0 To COMB_TYPES ' crel = ccE.Params.Relations.Get(q) ' Kcrel = KccE.Params.Relations.Get(q) 'Next k.Structure.Cases.CodeCmbEngine.Generate() End Sub
Hi, finally I have found out this:
If norma.Text = "EUROCODE" Then
robapp.Project.Preferences.SetActiveCode(RobotOM.IRobotCodeType.I_CT_STEEL_STRUCTURES, "UNE-EN 1993-1:2005/AC:2009")
robapp.Project.Preferences.SetActiveCode(RobotOM.IRobotCodeType.I_CT_CODE_COMBINATIONS, "EN 1990:2002")
End If
Dim engine As RobotOM.IRobotCodeCombinationEngine
Dim codecombination As RobotOM.RobotCodeCombinationEngine
Dim cmbparams As RobotOM.IRobotCodeCmbGenerationParams
codecombination = robapp.Project.Structure.Cases.CodeCmbEngine
codecombination.Params.GenType = RobotOM.IRobotCodeCmbGenerationType.I_CCGT_FULL
codecombination.Params.SelectCombinationType(RobotOM.IRobotCombinationType.I_CBT_ULS, True)
cmbparams = robapp.Project.Structure.Cases.CodeCmbEngine.Params
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_PERMANENT, RobotOM.IRobotCodeCmbOperator.I_CCO_AND, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_EXPLOATATION, RobotOM.IRobotCodeCmbOperator.I_CCO_AND_OR, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_WIND, RobotOM.IRobotCodeCmbOperator.I_CCO_EXCLUSIVE_OR, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_SEISMIC, RobotOM.IRobotCodeCmbOperator.I_CCO_EXCLUSIVE_OR, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_SNOW, RobotOM.IRobotCodeCmbOperator.I_CCO_AND, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_ACCIDENTAL, RobotOM.IRobotCodeCmbOperator.I_CCO_AND, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_TEMPERATURE, RobotOM.IRobotCodeCmbOperator.I_CCO_AND, "0")
codecombination.Generate()
HI Rafal Gaweda,
plz, I need help ...
How to use relations between groups with VBA
PERMANENT "G1" And "G2"
EXPLOITATION "Q1" OR"Q2"
"Definition of relations between groups. Definition of relations between groups can be illustrated by means of the matrix whose elements are group numbers. All groups whose numbers are located in the same matrix row are in the same relation with each other (either AND or AND_OR). Whereas among the matrix rows the relation EXCLUSIVE_OR occurs. ."
How to do relation between "G1" And "G2" with VBA plz
Thank ...
