Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API extract quantity survey
4 REPLIES 4
AbelSV78
677 Views, 4 Replies
Dear Sirs,
I need to stract data of Quantity Survey of all the structure from Robot. I need something similar to attached image. I have found out "Irobotstructurequantity" variable, but I do not know how to use it. Could you give me the code to extract it into excel from VB.net??
Thank you in advance, regards
4 REPLIES 4
Rafal.Gaweda
in reply to: AbelSV78
Example for Material and Bars survey:
Dim RobApp As New RobotApplication
Dim Mat As RobotMaterialQuantitySurvey
Dim MatLabel As RobotLabel
Dim MatData As RobotMaterialData
Row = 7
Set Mat = RobApp.Project.Structure.QuantitySurvey.Materials
For i = 1 To Mat.Count
    Cells(Row, 1) = Mat.GetName(i)
    Set MatLabel = RobApp.Project.Structure.Labels.Get(I_LT_MATERIAL, Mat.GetName(i))
    Set MatData = MatLabel.Data
    Cells(Row, 2) = MatData.E
    Cells(Row, 3) = MatData.Kirchoff
    Cells(Row, 4) = MatData.RO
    Cells(Row, 5) = MatData.NU
    Cells(Row, 6) = Mat.GetVolume(I_OT_BAR, i)
    Cells(Row, 7) = Mat.GetWeight(I_OT_BAR, i)
    Row = Row + 1
Next i
Row = Row + 1
Dim BQ As RobotBarSectionQuantitySurvey
Set BQ = RobApp.Project.Structure.QuantitySurvey.BarSections
For i = 1 To BQ.Count
    Cells(Row + i, 1) = BQ.GetName(i)
    Cells(Row + i, 2) = BQ.GetLength(i)
    Cells(Row + i, 3) = BQ.GetWeight(i)
    Cells(Row + i, 4) = BQ.GetVolume(i)
    Row = Row + 1
Next i
or create table I_TT_MEASURE and save it as txt (=csv)
Rafal Gaweda
AbelSV78
in reply to: Rafal.Gaweda
OK, it works..
thank you.
"or create table I_TT_MEASURE and save it as txt (=csv)" : could you give me a code example please...
It's possible do a code to get the quantity survey only a selected bar or a group of bars?
Thank you.
Best regards,
Rafal.Gaweda
By dumping filtered quantities table
Example:
Private Sub CommandButton1_Click()
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
Dim t As RobotTable
Dim tf As RobotTableFrame
Dim path As String
Dim Fullpath As String
Dim FName As String
path = Environ$("temp")
Dim nTables As Long
Set t = RobApp.Project.ViewMngr.CreateTable(I_TT_MEASURE, I_TDT_DEFAULT)
t.Select I_ST_BAR, "1 3to6" Set tf = RobApp.Project.ViewMngr.GetTable(1) FName = tf.Window.Caption spacepos = InStr(1, FName, " ") If spacepos <> 0 Then FName = Left(FName, spacepos - 1) + "_" End If tf.Get(1).Window.Activate Set t = tf.Get(1) tf.Current = 1 tabname = tf.GetName(1) tabname = Replace(tabname, " ", "_") DoEvents Fullpath = path + "\" + FName + tabname + ".txt" t.Printable.SaveToFile Fullpath, I_OFF_TEXT ansifilepath = Left(Fullpath, Len(Fullpath) - 4) + "_ansi.txt" X = Shell("cmd.exe /A /C TYPE " + Fullpath + " > " + ansifilepath, vbNormalFocus) DoEvents For Iii = 1 To 10000000 aaa = Iii Next Iii Workbooks.OpenText Filename:=ansifilepath, DataType:=xlDelimited, Semicolon:=True MsgBox "Dumping finished" Set RobApp = Nothing End Sub
Rafal Gaweda
