Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API - Error with RobotBarServer and geometrical objects
3 REPLIES 3
278 Views, 3 Replies
I have the following model:
If I run an add-in with the following code (where s is the RobotStructure and server is a RobotBarServer):
selBars = s.Selections.Get(IRobotObjectType.I_OT_BAR);
var bars = new List<IRobotBar>();
for (int i = 1; i <= sel.Count; i++)
    IRobotDataObject v = server.Get(selBars.Get(i)); //this is where the error occurs (see below)
    if(v as IRobotBar != null)
        bars.Add(v as IRobotBar);
return bars;
 while only the two bars are selected, I get a list containing both of these bars. sel.Count equals 2. And the function works fine.
If, however, I run that code with the entire model selected (beams, nodes and geometrical objects), sel.Count equals 5. Going through the method, I get both bars and then an error on the indicated line. Obviously the geometrical objects are being included in the selection, which implies they also have IRobotObjectType.I_OT_BAR. However, they aren't contained in the RobotBarServer, which is overflowing since I'm probably asking for bar 10, 11 or 12 (the indices of the geom. objects), which don't exist.
Trying a renumbering, I've noticed that bars and geom. objects share a numbering system (if I change bar 2 to 11, geom. object 11 becomes 2), so I could do a test with server.Exist(), but I'd like to know if there's a simpler way to do it. Is there?
Tags (2)
3 REPLIES 3
Rafal.Gaweda
Wrong. Need to be corrected
Use such code:
    Dim BarSel As RobotSelection
    Set BarSel = RobApp.Project.Structure.Selections.Get(I_OT_BAR)
    Dim Bars As RobotBarCollection
    Set Bars = RobApp.Project.Structure.Bars.GetMany(BarSel)
 and Bars.Count will return only number of bars and make loop in Bars Collection.
Rafal Gaweda
in reply to: Rafal.Gaweda
Just to be clear, instead of using List<IRobotBar>, I should use RobotBarCollection?
Rafal.Gaweda
Yes.
Rafal Gaweda
