I have the following model:
If I run an add-in with the following code (where s is the RobotStructure and server is a RobotBarServer):
selBars = s.Selections.Get(IRobotObjectType.I_OT_BAR); var bars = new List<IRobotBar>(); for (int i = 1; i <= sel.Count; i++) { IRobotDataObject v = server.Get(selBars.Get(i)); //this is where the error occurs (see below) if(v as IRobotBar != null) bars.Add(v as IRobotBar); } return bars;
while only the two bars are selected, I get a list containing both of these bars. sel.Count equals 2. And the function works fine.
If, however, I run that code with the entire model selected (beams, nodes and geometrical objects), sel.Count equals 5. Going through the method, I get both bars and then an error on the indicated line. Obviously the geometrical objects are being included in the selection, which implies they also have IRobotObjectType.I_OT_BAR. However, they aren't contained in the RobotBarServer, which is overflowing since I'm probably asking for bar 10, 11 or 12 (the indices of the geom. objects), which don't exist.
Trying a renumbering, I've noticed that bars and geom. objects share a numbering system (if I change bar 2 to 11, geom. object 11 becomes 2), so I could do a test with server.Exist(), but I'd like to know if there's a simpler way to do it. Is there?
Solved by Rafal.Gaweda. Go to Solution.
Wrong. Need to be corrected
Use such code:
Dim BarSel As RobotSelection Set BarSel = RobApp.Project.Structure.Selections.Get(I_OT_BAR) Dim Bars As RobotBarCollection Set Bars = RobApp.Project.Structure.Bars.GetMany(BarSel)and Bars.Count will return only number of bars and make loop in Bars Collection.
