Hi All,
I am modelling a series of portal framed buildings and using cladding panels with uniform FE loading and geometric limits to apply the wind loads and I was wondering whether anybody could advise me how to set up geometric limits when editing the loads in Excel. I have to copy to Excel using the text edition of the loads but when I copy back in to Robot then the geometric limits part is ignored (see below for an example of what is pasted back in).
Rich
3:TW1 | (FE) uniform | 190 191 | PZ=0.73(kN/m2) Geometrical limits:P1(11.3, 0, 0) P2(11.3, -1, 0) P3(11.3, 0, 1) P4(10.3, 0, 0) |
Data which is hidden under buttons in tables is not copied by clipboard.
You can edit these data in Excell but small API macro is required to be used.
I am attaching emaxple xls file with macro for FE unifrom load.
Write case number in B2 field, import data. Do not update Record numbers cells, after updating xls use update buttton.
If limit points coordinates cells not filled with data ti means limits not set.
Thank you for this nice macro. But I am getting an error while updating the load value (PZ) as shown in the attached picture.
On other note I would like to ask if we have a macro from which we can extract all type of loads (not just FE unform) in excel and update accordingly in excel only. After that If I can update the loads in robot automatically through macro itself.
Try to debug it.
No. Fot this prupose you have Loads table in Robot.
Hi Rafal,
Thanks for your quick reply. I tried but couldnt debug the issue. I tried using it on a different robot model too but the result was same. Could you please look into it?
Thanks.
