Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) Divide bars
9 REPLIES 9
Message 1 of 10
samuel.pereira
980 Views, 9 Replies
(API) Divide bars
I want divide bars using API macro in Excel. For example, divide bar number 2 into 4 parts.
You can provide an example?
Thanks.
9 REPLIES 9
Message 2 of 10
Dim RVA As New RobotValuesArray
RVA.SetSize 3
RVA.Set 1, 0.25
RVA.Set 2, 0.5
RVA.Set 3, 0.75
barnumber=2 RobApp.Project.Structure.Edit.DivideBar barnumber, RVA, True
Rafal Gaweda
Message 3 of 10
When I run the the API in Excel, it show an error. I attached the error. Can you help me?
Thank you and best regards
Message 4 of 10
Message 5 of 10
Try:
Dim RVA As RobotValuesArray
Set RVA = RobApp.CmpntFactory.Create(I_CT_VALUES_ARRAY)
Rafal Gaweda
Message 6 of 10
It works. Thanks.
It's possible generate the nodes without bar division?
Thank you and best regards.
Message 7 of 10
Of course. Write your own divide function
- calculate bar vector
- normalize it to 1
- use startnode + normalized vector to generate node in proper position or endnode and opposite vector to normalized one
or use this 🙂
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-for-merging-bars/td-p/3817730
Rafal Gaweda
Message 8 of 10
Ok.
Can you provide an example.
Message 9 of 10
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
Dim RBar As RobotBar
Dim StartNode As RobotNode
Dim EndNode As RobotNode
Dim Relative As Boolean
BarNumber = 2
Distance = 0.3
Relative = True
Set RBar = RobApp.Project.Structure.Bars.Get(BarNumber)
Set StartNode = RobApp.Project.Structure.Nodes.Get(RBar.StartNode)
Set EndNode = RobApp.Project.Structure.Nodes.Get(RBar.EndNode)
Dim Vx As Double, Vy As Double, Vz As Double, VL As Double
'bar vector
Vx = EndNode.x - StartNode.x
Vy = EndNode.y - StartNode.y
Vz = EndNode.z - StartNode.z
'vector length
VL = Sqr(Vx * Vx + Vy * Vy + Vz * Vz)
'normalization
Vx = Vx / VL
Vy = Vy / VL
Vz = Vz / VL
'new node
If Relative Then
    Distance = Distance * VL
RobApp.Project.Structure.Nodes.Create RobApp.Project.Structure.Nodes.FreeNumber, _
                                        StartNode.x + Vx * Distance, _
                                        StartNode.y + Vy * Distance, _
                                        StartNode.z + Vz * Distance
Rafal Gaweda
Message 10 of 10
Thank you very much!!
