(API) Deformed geometry update
6 REPLIES 6
sunwaymas
1654 Views, 6 Replies
I am not sure if Robot can do this.
I need to do an analysis on a "Deformed structure" to model Initial Imperfection. What I previously did on Lusas is that I set up a non-deformed model, applied loading to the model until the required deformation is achieved, then save the deformed geometry (without lock-in stresses) for later use.
Cheers
sunwaymas
6 REPLIES 6
Rafal.Gaweda
in reply to: sunwaymas
sunwaymas
in reply to: Rafal.Gaweda
Thank you. This is exactly what I wanted to do.
It means Robot can't do it by default...??
Rafal.Gaweda
Can not do it by default
Rafal Gaweda
sunwaymas
Thanks Rafal 🙂
Rafal.Gaweda
I found it in my drawer 🙂
Maybe enough for you.
This macro updates model geometry taking into account deformation of selected case
Rafal Gaweda
sunwaymas
Hi Rafal,
Thank you so much 🙂
