I have a very large structure being analyzed using RSA. Defining provided reinforcement for columns consumes a lot of time to do it. It may be better to define the provided reinforcement in Excel sheet and create it in RSA using vb.net/vba.
Any body who can provide a vb.net/vba code of doing this. Thanks.
Solved by buchack. Go to Solution.
You may consider use of the typical reinforcement dialog and saving several patterns of reinforcements which you can them use for selected columns from the model.
Here is an example in VBA that creates column with reinforcement. After some modifications it may be used to generate reinforcing bars in existing columns.
To run example Robot regional settings must be set to US (bar shapes "1" and "T1" are hardcoded).
This macro uses two references: 'Robot Object Model v. 15.0' and 'ROBarShapeDb 2015.0 Type Library'.
Sub CreateColumntWithReinforcement() Dim app As New RobotOM.RobotApplication app.Visible = 1 app.Window.Activate app.Project.New (IRobotProjectType.I_PT_CONCRETE_COLUMN) Dim column As RobotOM.IRConcrColumn Set column = app.Project.ComponentMngr.Create(IRobotProjectComponentType.I_PCT_COLUMN, "Column.1", "Level1").Data Dim reinf As IRConcrReinforcement Set reinf = column.Reinforcement Dim bars As IRConcrReinforcingBars Set bars = reinf.bars Dim geom As IRConcrColumnGeometry Set geom = column.Geometry Dim cover As Double cover = 0.05 Dim diameterLong As Double diameterLong = 0.012 Dim diameterTran As Double diameterTran = 0.006 Dim bendDiamLong As Double bendDiamLong = 0.1 Dim h As Double h = geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_HSD) + geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_EPD) ' lock refresh during generation for better performance Dim wasLocked As Boolean wasLocked = reinf.LockRefresh(True) reinf.RemoveAll Dim pi As Double pi = 3.1415926 ' create longituginal bars Dim y(4) As Double Dim z(4) As Double y(0) = cover y(1) = geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_A) - cover y(2) = geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_A) - cover y(3) = cover z(0) = cover z(1) = cover z(2) = geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_B) - cover z(3) = geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_B) - cover Dim bar As IRConcrReinforcingBar Dim attr As IRbctAttribute Dim p As IRbctData Dim barEditor As IROBarEditor For j = 1 To 4 Set bar = bars.Add("1", IRConcrBarType.I_CBT_BAR_TYPE_LON_MAIN, IRConcrBarSubtype.I_CBS_BAR_SUBTYPE_DOWN, diameterLong, bendDiam) Set barEditor = bar.GetROBarEditor(False) Set p = barEditor.GetData() Set attr = p.GetAttribute("RBCR_ATT_BAR_TEMPLATE_PARAM", 0) attr.SetDoubleValue "RBCR_PAR_SHAPEPARAM", (h - 2 * cover) * 1000#, -1 ' bar length Set attr = p.GetAttribute("RBCR_ATT_BAR_DEFPARAM", -1) attr.SetDoubleValue "RBCR_PAR_BAR_HOOKA1", pi * 3 / 4#, -1 ' hook angle attr.SetDoubleValue "RBCR_PAR_BAR_HOOKL1", 100, -1 ' hook len attr.SetDoubleValue "RBCR_PAR_BAR_HOOKA2", pi * 3 / 4#, -1 attr.SetDoubleValue "RBCR_PAR_BAR_HOOKL2", 100, -1 bar.SetROBarEditor barEditor bar.SetDirections 0, y(j Mod 4) - y((j + 2) Mod 4), z(j Mod 4) - z((j + 2) Mod 4), -1, 0, 0 bar.Position.X = cover bar.Position.y = y(j - 1) bar.Position.z = z(j - 1) bar.SteelType = I_CST_STEEL_TYPE_LONG Next j ' create transversal bars For K = 1 To 10 Set bar = bars.Add("T1", IRConcrBarType.I_CBT_BAR_TYPE_TRA_MAIN, IRConcrBarSubtype.I_CBS_BAR_SUBTYPE_ANY, diameterTran, 0#) Set barEditor = bar.GetROBarEditor(False) Set p = barEditor.GetData() Set attr = p.GetAttribute("RBCR_ATT_BAR_TEMPLATE_PARAM", 0) attr.SetDoubleValue "RBCR_PAR_SHAPEPARAM", (geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_A) - 2 * cover) * 1000#, -1 Set attr = p.GetAttribute("RBCR_ATT_BAR_TEMPLATE_PARAM", 1) attr.SetDoubleValue "RBCR_PAR_SHAPEPARAM", (geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_B) - 2 * cover) * 1000#, -1 Set attr = p.GetAttribute("RBCR_ATT_BAR_TEMPLATE_PARAM", 2) attr.SetDoubleValue "RBCR_PAR_SHAPEPARAM", (geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_A) - 2 * cover) * 1000#, -1 Set attr = p.GetAttribute("RBCR_ATT_BAR_TEMPLATE_PARAM", 3) attr.SetDoubleValue "RBCR_PAR_SHAPEPARAM", (geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_B) - 2 * cover) * 1000#, -1 Set attr = p.GetAttribute("RBCR_ATT_BAR_DEFPARAM", -1) attr.SetDoubleValue "RBCR_PAR_BAR_HOOKA1", pi * 3 / 4#, -1 bar.SetROBarEditor barEditor bar.DirectionZ.z = -bar.DirectionZ.z bar.Position.X = K * h / 10# bar.Position.y = geom.Dim(IRConcrColumnDimensionType.I_CCD_COLUMN_DIM_B) - cover bar.Position.z = cover bar.SteelType = I_CST_STEEL_TYPE_TRAN Next K reinf.LockRefresh (wasLocked) reinf.Comment = "Generated by VBA" reinf.Freeze True app.UserControl = True End Sub
I have Robot 2014 student version and i just have 'Robot Object Model v.14.0', the other reference ('ROBarShape Db 2015.0 Type Library) i don't.
What can i do for have this references? Install Robot 2015?
Regards
Good day Krzysztof,
How can I assign the created column reinforcements to existing bar using vb.net/vba?
Thank you.
Hello all.
This was very interesting but i need the code not to create but to get the reinforcement already defined on the "provided reinforcement tab" from RSA.
Is it possible? With C# how can I get the defined reinforcement from RSA?
Thank you
Regards
