API Crash on exit
5 REPLIES 5
351 Views, 5 Replies
API Crash on exit
I'm using vb.net 2010 with Robot RSA 2011 sp6 and 2012 sp5
I've got a crash on exiting Robot when my programm exit or when I call closeRobot like that :
Public Shared gRobotApplication As RobotOM.RobotApplication = New RobotOM.RobotApplication()
        Private Shared gProjet As RobotOM.RobotProject = Nothing
 Public Shared Sub closeRobot()
                If gProjet IsNot Nothing Then
                    gProjet.Close()
                    gProjet = Nothing
                End If
                If gRobotApplication IsNot Nothing Then
                    gRobotApplication.Quit(IRobotQuitOption.I_QO_DISCARD_CHANGES)
                    gRobotApplication = Nothing
                End If
        End Sub
5 REPLIES 5
Mirko.Jurcevic
Have you tried by using interfaces:
Public Shared gRobotApplication As RobotOM.IRobotApplication = New RobotOM.IRobotApplication()
Private Shared gProjet As RobotOM.IRobotProject = Nothing
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
thx
it doesn't works... error :
Impossible d'effectuer un cast d'un objet COM de type 'System.__ComObject' en type d'interface 'RobotOM.IRobotApplication'. Cette opération a échoué, car l'appel QueryInterface sur le composant COM pour l'interface avec l'IID '{F787078F-CDE5-11D1-8FF1-00A02447BAAE}' a échoué en raison de l'erreur suivante : Cette interface n’est pas prise en charge (Exception de HRESULT : 0x80004002 (E_NOINTERFACE)).
Mirko.Jurcevic
You're right. My answer was wrong.
Have you set reference to RobotOM?
I've tested this code and works for me:
Public Class Form1
            gProjet.Close()
            gProjet = Nothing
        End If
            gRobotApplication.Quit(RobotOM.IRobotQuitOption.I_QO_DISCARD_CHANGES)
        End If
    End Sub
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        closeRobot()
    End Sub
End Class
I use C#, I'm not so much used to VB.NET ...
Mirko Jurcevic
Try this approach to register / reregister interfaces:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/VBA-Excel-macro-for-any-object-geometry-modi...
Rafal Gaweda
in reply to: Rafal.Gaweda
I've a solution that works, all others I've tried do not work
Public Shared gRobotApplication As RobotOM.IRobotApplication = Nothing
Public Shared Sub killRobot()
Try
Dim PR As Process() = Process.GetProcessesByName("robot")
If PR.Length > 0 Then
For Each P As Process In PR
Try
gRobotApplication = New RobotOM.RobotApplication
gRobotApplication.Interactive = CInt(False)
gRobotApplication.Project.Close()
P.CloseMainWindow()
Catch ex As Exception
addError(ex)
End Try
Next
End If
addError(ex)
End Try
End Sub
