Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) Correct Modal analysis?
28 REPLIES 28
Message 1 of 29
jokiller70
907 Views, 28 Replies
Am I doing this right? I get the same Frequency even if I add loads?
Tags (2)
28 REPLIES 28
Message 2 of 29
Rafal.Gaweda
in reply to: jokiller70
In all loadcases only SW is considered so the results are the same
Rafal Gaweda
Message 3 of 29
jokiller70
in reply to: Rafal.Gaweda
From API? Do you have any samples?
Message 4 of 29
Rafal.Gaweda
Important - masses are added to case   -1
Private Sub CommandButton1_Click()
Dim robapp As RobotApplication
Set robapp = New RobotApplication
    Dim cas As RobotSimpleCase
    Dim rec As RobotLoadRecord
Set cas = robapp.Project.Structure.Cases.Get(-1)
Set rec = cas.Records.Create(I_LRT_MASS_ACTIVATION)
    rec.SetValue I_MARV_FACTOR, 1.3
    rec.SetValue I_MARV_CASE_NUM, 3
    rec.SetValue I_MARV_ACTIVATION_DIR, 2
    rec.SetValue I_MARV_SIGN, 1
End Sub
Rafal Gaweda
Message 5 of 29
jokiller70
Shall I use -1 as loadcase? Or the actual one I would like to calculate? Also which frequenzy is the correct one?
eigval = robapp.Project.Structure.Results.Advanced.Eigenvalues.Value(icomb, ncomb)
ncomb 1 is always hig and ncomb 10 is very low. (Does not match our tested values)
Message 6 of 29
Rafal.Gaweda
-1 is a loadcase number to which you convert loads onto masses
No idea what you are talking about.
Rafal Gaweda
Message 7 of 29
jokiller70
So 4,18 is the lowest possible frequency that can occur?
And shall I add loadcase -1 to my load combination?
Message 8 of 29
Rafal.Gaweda
These results comes from the model you attached - load case 1
You can not add converted masses case to anything.
Rafal Gaweda
Message 9 of 29
jokiller70
The code you sent (CommandButton1_Click()) does not seem to generate any load to mass generation.
Message 10 of 29
Rafal.Gaweda
This was example code how to deal with load to mass conversion from API.
Not related to your model
Rafal Gaweda
Message 11 of 29
jokiller70
Is there any way to invoke the "Disregard density" ?
Message 12 of 29
Rafal.Gaweda
Example:
Rafal Gaweda
Message 13 of 29
jokiller70
I would realy like to have that code! It is not possible to fullscreen your video so I can not read int .,(
Message 14 of 29
jokiller70
So I figured it out. But now it wont calculate. When i modify the "Load to mass coversion" with the exact same values it works...
https://screencast.autodesk.com/main/details/d2cc0bad-66f5-49a6-b376-f819c69e1f2e
Message 15 of 29
Rafal.Gaweda
Example code (model generation is required to be run (forced to be run))
    Dim ModalParams As RobotModalAnalysisParams
    Dim ModalCase As RobotSimpleCase
    Set ModalCase = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, "Modal", I_CN_EXPLOATATION, I_CAT_DYNAMIC_MODAL)
    Set ModalParams = ModalCase.GetAnalysisParams
    ModalParams.DisregardDensity = True
    ModalCase.SetAnalysisParams ModalParams
    rec.SetValue I_MARV_FACTOR, 1.2
    rec.SetValue I_MARV_CASE_NUM, 2
    rec.SetValue I_MARV_SIGN, -1
    rec.SetValue I_MARV_INPUT_DIR_X, 1
    rec.SetValue I_MARV_INPUT_DIR_Y, 1
    rec.SetValue I_MARV_INPUT_DIR_Z, 1
    robapp.Project.CalcEngine.GenerateModel
End Sub
Rafal Gaweda
Message 16 of 29
Rafal.Gaweda
or
or
    robapp.Project.CalcEngine.AutoGenerateModel = True
Rafal Gaweda
Message 17 of 29
jokiller70
Tried both, still same problem as in my video...
Message 18 of 29
Rafal.Gaweda
Send me your this file.
Rafal Gaweda
Message 19 of 29
jokiller70
When i add automaticaly generat to mass to load conversion, thoose works.
Message 20 of 29
Rafal.Gaweda
This is what I see:
Rafal Gaweda
