Am I doing this right? I get the same Frequency even if I add loads?
Solved by jokiller70. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
In all loadcases only SW is considered so the results are the same
Important - masses are added to case -1
Private Sub CommandButton1_Click() Dim robapp As RobotApplication Set robapp = New RobotApplication Dim cas As RobotSimpleCase Dim rec As RobotLoadRecord Set cas = robapp.Project.Structure.Cases.Get(-1) Set rec = cas.Records.Create(I_LRT_MASS_ACTIVATION) rec.SetValue I_MARV_FACTOR, 1.3 rec.SetValue I_MARV_CASE_NUM, 3 rec.SetValue I_MARV_ACTIVATION_DIR, 2 rec.SetValue I_MARV_SIGN, 1 End Sub
Shall I use -1 as loadcase?
-1 is a loadcase number to which you convert loads onto masses
eigval = robapp.Project.Structure.Results.Advanced.Eigenvalues.Value(icomb, ncomb)
ncomb 1 is always hig and ncomb 10 is very low. (Does not match our tested values)
No idea what you are talking about.
These results comes from the model you attached - load case 1
You can not add converted masses case to anything.
So I figured it out. But now it wont calculate. When i modify the "Load to mass coversion" with the exact same values it works...
https://screencast.autodesk.com/main/details/d2cc0bad-66f5-49a6-b376-f819c69e1f2e
Example code (model generation is required to be run (forced to be run))
Private Sub CommandButton1_Click() Dim robapp As RobotApplication Set robapp = New RobotApplication Dim cas As RobotSimpleCase Dim rec As RobotLoadRecord Dim ModalParams As RobotModalAnalysisParams Dim ModalCase As RobotSimpleCase Set ModalCase = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, "Modal", I_CN_EXPLOATATION, I_CAT_DYNAMIC_MODAL) Set ModalParams = ModalCase.GetAnalysisParams ModalParams.DisregardDensity = True ModalCase.SetAnalysisParams ModalParams Set cas = robapp.Project.Structure.Cases.Get(-1) Set rec = cas.Records.Create(I_LRT_MASS_ACTIVATION) rec.SetValue I_MARV_FACTOR, 1.2 rec.SetValue I_MARV_CASE_NUM, 2 rec.SetValue I_MARV_ACTIVATION_DIR, 2 rec.SetValue I_MARV_SIGN, -1 rec.SetValue I_MARV_INPUT_DIR_X, 1 rec.SetValue I_MARV_INPUT_DIR_Y, 1 rec.SetValue I_MARV_INPUT_DIR_Z, 1 robapp.Project.CalcEngine.GenerateModel End Sub
or
robapp.Project.CalcEngine.GenerateModel or robapp.Project.CalcEngine.AutoGenerateModel = True
When i add automaticaly generat to mass to load conversion, thoose works.
