Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API buckling length problems
28 REPLIES 28
Message 1 of 29
AbelSV78
1741 Views, 28 Replies
Hi everyone again,
I am trying to define an structure with VB.net and I have problems with buckling length. I am defining it with:
 With RdmMembDefData
            .SetStructureSwayYZ(RobotOM.IRDimMembDefBucklingDataType.I_DMDBDT_BUCKLING_Y, 1)
            .SetLengthYZUV(RobotOM.IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Y, 1.0#)
            .SetStructureSwayYZ(RobotOM.IRDimMembDefBucklingDataType.I_DMDBDT_BUCKLING_Z, 1)
            .SetLengthYZUV(RobotOM.IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Z, 1.0#)
            .SetDeflectionYZ(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, 1)
            .SetDeflectionYZ(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 1)
            .SetDeflYZRelLimit(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, 10.0#)
            .SetDeflYZRelLimit(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 10.0#)
            .CantileverMode = 1
            .SetDisplacementXY(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_X, 1)
            .SetDisplacementXY(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, 1)
            .SetDisplXYRelLimit(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_X, 10.0#)
            .SetDisplXYRelLimit(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, 10.0#)
        End With
but I have obtained a numeric length of the bars. I want to enter a coefficient for "Y" and a  coefficient for "Z", which is the correct method?
Thanks...
28 REPLIES 28
Message 21 of 29
Thank you for your answer, but I have already tried this code. All the "RDimMembParams..." works but the "RdimLabelData.Set.." doesn't work especially for wood members with IRDimMembParamsE52 norm.
It works for IRDimMembParamsE32 for steel members. Here is my code :
Dim Robot As RobotOM.IRobotApplication = Rob
 Robot.Project.Preferences.SetActiveCode(IRobotCodeType.I_CT_TIMBER_STRUCTURES, "NF EN 1995-1:2005/NA:2010/A1:2008")
Dim RLabel2 As IRobotLabel = Robot.Project.Structure.Labels.Create(IRobotLabelType.I_LT_MEMBER_TYPE, "TYPE-TRAVERSE")
Dim RdimLabelData As IRDimMembDefData = RLabel2.Data
Dim RDimMembParams As IRDimMembParamsE52 = RdimLabelData.CodeParams
RDimMembParams.BuckLengthCoeffY = clfy
RDimMembParams.BuckLengthCoeffZ = clfz
RdimLabelData.Type = IRDimMembDefType.I_DMDT_USER
RdimLabelData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, 100)
RdimLabelData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 100)
RdimLabelData.SetDeflectionYZ(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, 1)
RdimLabelData.SetDeflectionYZ(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 1)
RdimLabelData.CantileverMode = 1
RdimLabelData.SetDisplXYRelLimit(IRDimMembDefDispDataType.I_DMDDDT_DISP_X, 100)
RdimLabelData.SetDisplXYRelLimit(IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, 100)
RdimLabelData.SetDisplacementXY(IRDimMembDefDispDataType.I_DMDDDT_DISP_X, 1)
RdimLabelData.SetDisplacementXY(IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, 1)
RdimLabelData.CodeParams = RDimMembParams
Robot.Project.Structure.Labels.StoreWithName(RLabel2, "TYPE-TRAVERSE")
Best Regards,
Charles THIERRY DE VILLE D'AVRAY
villedavray_charles@yahoo.fr
Message 22 of 29
I think the reason is I used Labels.CreateLike to force robot creating a "wood member" and the wood member "Barre bois" has no service parameters by default.
Dim RLabel2 As IRobotLabel = Robot.Project.Structure.Labels.CreateLike(IRobotLabelType.I_LT_MEMBER_TYPE, NomTypeBarreBois, "Barre bois")
If I use only Labels.Create Robot will create a "Steel Member" by default.
Do you now how can I force Robot to create a wood member without using "Labels.CreateLike"?
Best Regards,
Message 23 of 29
I found the solution :
"Dim RDimMembParams"  must be after all the "RdimLabelData.Set..."
The order is important...
Here is the false code :
Dim PredefinedLabel As String = Robot.Project.Structure.Labels.GetPredefinedName(IRobotPredefinedLabel.I_PL_MEMBER_TYPE_TIMBER_BEAM)
Dim RLabel2 As IRobotLabel = Robot.Project.Structure.Labels.CreateLike(IRobotLabelType.I_LT_MEMBER_TYPE, NomTypeBarreBois, PredefinedLabel)
RdimLabelData.SetLengthYZUV(IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Y, lfy)
RdimLabelData.SetLengthYZUV(IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Z, lfz)
RdimLabelData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, FlecheFinaleY)
RdimLabelData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, FlecheFinaleZ)
RdimLabelData.SetDisplXYRelLimit(IRDimMembDefDispDataType.I_DMDDDT_DISP_X, depX)
RdimLabelData.SetDisplXYRelLimit(IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, depY)
Robot.Project.Structure.Labels.StoreWithName(RLabel2, NomTypeBarreBois)
Here is the right code :
        Dim RDimMembParams As IRDimMembParamsE52 = RLabel2.Data.CodeParams
Best Regards,
Message 24 of 29
There is only one problem now with the 'RelLimitDeflUy'  and 'RelLimitdeflUz'
(You can see what I mean with the following picture)
RDimMembParams.RelLimitDeflUy = FlecheRelativeY
RDimMembParams.RelLimitdeflUz = FlecheRelativeZ
Is it possible to set these parameters with IRDimMembParamsE52  norm?
Best Regards,
Message 25 of 29
These settings are not implemented in API
Rafal Gaweda
Message 26 of 29
Exactly
Rafal Gaweda
Message 27 of 29
paul.bassLH
in reply to: Rafal.Gaweda
Hi @Rafal.Gaweda ,
Just a question about this: does it mean that we cannot use API to define member type in Russian code as SP 16.13330.2011 (nothing about russian code in IRDimMembersParamxxxx)?
I need to change 30 member typ in 24 calculation model...
Thank you
Message 28 of 29
Romanich
in reply to: paul.bassLH
Hi @paul.bassLH ,
I can't check now, but it seems that we cannot use API to define member type in Russian code as SP 16.13330.2011.
I would suggest a small workaround:
  1.  In one calculation model update your member types and save it in the Label Manager
  2.  Open next model and copy all member types from the Label Manager
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 29 of 29
HadiMoosavi
I just came to the point in my code where  I am going to define code design parameters. I am working with Canadian code.
IRobotApplication robApp = new RobotApplication();
RobotStructure structure = robApp.Project.Structure;
robApp.Project.Preferences.SetActiveCode(IRobotCodeType.I_CT_STEEL_STRUCTURES, designCode);
RobotLabelServer labelServer = structure.Labels;
IRobotLabel beamDesignParametersLabel = labelServer.Create(IRobotLabelType.I_LT_MEMBER_TYPE, "simple beam");
IRDimMembDefData beamDesignParametersData = (IRDimMembDefData)beamDesignParametersLabel.Data;
IRDimMembParamsCAN beamDesignParameters = (IRDimMembParamsCAN)beamDesignParametersData.CodeParams;
labelServer.Store(beamDesignParametersLabel);
but I am getting this error. Can anyone help with this?
