Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API buckling length problems
28 REPLIES 28
Message 1 of 29
AbelSV78
1742 Views, 28 Replies
Hi everyone again,
I am trying to define an structure with VB.net and I have problems with buckling length. I am defining it with:
 With RdmMembDefData
            .SetStructureSwayYZ(RobotOM.IRDimMembDefBucklingDataType.I_DMDBDT_BUCKLING_Y, 1)
            .SetLengthYZUV(RobotOM.IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Y, 1.0#)
            .SetStructureSwayYZ(RobotOM.IRDimMembDefBucklingDataType.I_DMDBDT_BUCKLING_Z, 1)
            .SetLengthYZUV(RobotOM.IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Z, 1.0#)
            .SetDeflectionYZ(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, 1)
            .SetDeflectionYZ(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 1)
            .SetDeflYZRelLimit(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, 10.0#)
            .SetDeflYZRelLimit(RobotOM.IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, 10.0#)
            .CantileverMode = 1
            .SetDisplacementXY(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_X, 1)
            .SetDisplacementXY(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, 1)
            .SetDisplXYRelLimit(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_X, 10.0#)
            .SetDisplXYRelLimit(RobotOM.IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, 10.0#)
        End With
but I have obtained a numeric length of the bars. I want to enter a coefficient for "Y" and a  coefficient for "Z", which is the correct method?
Thanks...
28 REPLIES 28
Message 2 of 29
Rafal.Gaweda
in reply to: AbelSV78
It is numeric length of the bars
Rafal Gaweda
Message 3 of 29
AbelSV78
in reply to: Rafal.Gaweda
I am trying with this:
Dim RdmCodeMembDefPar As Object
RdmCodeMembDefPar = RdmMembDefData.CodeParams
With RdmCodeMembDefPar
.BuckLenghtCoeffY = 1.0#
.BucklingDiagramY = "I_DBD_CM66_NO"
.BuckLenghtCoeffZ = 0.8
.BucklingDiagramZ = I_DBD_CM66_PINNED_STIFF_0_7
.LoadTypeY = I_DLT_CM66_NO_MID_SPAN_FORCE_LOAD
.LoadTypeZ = I_DLT_CM66_USR_DEF_MOM_MC
.LoadTypeDistY = 2.0#
.LoadTypeMomMcZ = 26.0#
.LatBuckType = I_DLBT_CM66_CANTILEVER
.LoadLevel = I_DLL_CM66_UPP_SECT_PAR_LOADED
.LoadLevelValue = 1.2
.LatBuckCoef_LowFlan = I_DLBCD_CM66_USER_DEFINED
.LatBuckCoef_UppFlan = I_DLBCD_CM66_USER_DEFINED
.UserDefLatBuckCoef_LowFlan = 0.7
.UserDefLatBuckCoef_UppFlan = 0.9
.TensAreaNetGros = 1.1
.TubeControl = 1
End With
RdmMembDefData.CodeParams = RdmCodeMembDefPar
but it does not work in order to enter a coefficient for buckling length. Is there any way to enter this coefficient?
Thank you...
Message 4 of 29
Rafal.Gaweda
Example:
 RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ENV 1993-1:1992"
    Dim RLabel As IRobotLabel
    Dim RdimLabelData  As IRDimMembDefData
    Dim RDimMembParams As IRDimMembParamsEC3
        Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "My Label")
        Set RdimLabelData = RLabel.Data
        RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Y, 100
        RdimLabelData.SetDeflYZRelLimit I_DMDDDT_DEFL_Z, 200
        RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_X, 300
        RdimLabelData.SetDisplXYRelLimit I_DMDDDT_DISP_Y, 400
        Set RDimMembParams = RdimLabelData.CodeParams
        RDimMembParams.BuckLengthCoeffY = 10
        RdimLabelData.CodeParams = RDimMembParams
        RobApp.Project.Structure.Labels.Store RLabel
        Set RLabel = Nothing
End If
Rafal Gaweda
Message 5 of 29
AbelSV78
thanks again, but I have some troubles with "RDimMembParams = RdimLabelData.CodeParams", see attachment.
regards..
Message 6 of 29
Rafal.Gaweda
Upps , sorry.
Correct line with correct code name:
RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "EC3"
Rafal Gaweda
Message 7 of 29
AbelSV78
Thank you, but it works with EC3 code only.
I am trying with other codes, and it doesn' work. I need:
UNE-EN 1993:2008/AC:2009
ANSI/AISC 360-05
The member type difinition window is different in each code, but the names of the parameters are the same.
Regards...
Message 8 of 29
Rafal.Gaweda
    RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "ANSI/AISC 360-05"
    Dim RDimMembParams As IRDimMembParamsANS
        RDimMembParams.BuckLenghtCoeffY = 10
Rafal Gaweda
Message 9 of 29
AbelSV78
I am checking the previous code, It works. Then I am trying with other codes, and I have found out a trouble. In "RobotOM.IRDimMembParams" we have 9-10 options, but in Robot, we have a lot of options (see attached). Because of these, is it possible to design with API taking into account all codes included in ROBOT? We need some of them to develop our projects. And more important, HOW? 🙂
Thank you for your efforts...
Message 10 of 29
Rafal.Gaweda
No, or I least I do not think so.
Rafal Gaweda
Message 11 of 29
AbelSV78
I can see, It is a bit limitated. About EC3, take care, with this option code, Robot takes not actual Eurocodes Standards.
Thank you again and we will look for news about this in the future...
Message 12 of 29
Rafal.Gaweda
EC3 = ENV 1993-1:1992
Rafal Gaweda
Message 13 of 29
AbelSV78
It is OK, but, ENV are provisional and in ROBOT it is possible to select EN 1993-1:2005/AC:2009, the actual one...
Message 14 of 29
Rafal.Gaweda
EC3_2004 = EN 1993-1:2005/AC:2009
    RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "EC3_2004"
    Dim RDimMembParams As IRDimMembParamsE32
Rafal Gaweda
Message 15 of 29
Rafal.Gaweda
EC3_2004_ESP = UNE-EN 1993:2008/AC:2009
    RobApp.Project.Preferences.SetActiveCode I_CT_STEEL_STRUCTURES, "EC3_2004_ESP"
You can find code names: "c:\ProgramData\Autodesk\Structural\Common Data\2014\Data\Other\norms.xls" , B column to be used in API , RDIM part - steel codes
Rafal Gaweda
Message 16 of 29
AbelSV78
Thank yo so much, this is what we are waiting for; is there another table with equvalences to IRDimMembParams*******??
Message 17 of 29
Rafal.Gaweda
No
EC3, E32 - steel eurocodes
the rest is rather clear
Rafal Gaweda
Message 18 of 29
AbelSV78
Ok, thank you so much again, I will try...
Message 19 of 29
I try to set Buckling Length for timber bar type using Eurocode 5 (RDimMembParamsE52 )
It works for steel bar type, but I don't understand why it doesn't work for wood bar type.
Have you any ideas to solve this problem?
I see the same problem with the definition of deflection limit and nodes displacement limite (ULS).
Others parameters like buckling coefficient work very well.
(I use Robot 2012)
Best regards,
Charles THIERRY DE VILLE D'AVRAY
villedavray_charles@yahoo.fr
(You can send me an email at this adress)
---------------------Here is the code I try to use----------------------
Dim Robot As RobotOM.IRobotApplication = Rob
'Création d'un nouveau type de barre
Dim RLabel2 As IRobotLabel = Robot.Project.Structure.Labels.CreateLike(IRobotLabelType.I_LT_MEMBER_TYPE, NomTypeBarreBois, "Barre bois")
Dim RdimLabelData As IRDimMembDefData = RLabel2.Data
Dim RDimMembParams As IRDimMembParamsE52 = RdimLabelData.CodeParams
RdimLabelData.Type = IRDimMembDefType.I_DMDT_USER
'Définir les longueurs de flambement autour de l'axe Y
RdimLabelData.SetLengthYZUV(IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Y, 255)
'Définir les longueurs de flambement autour de l'axe Z
RdimLabelData.SetLengthYZUV(IRDimMembDefLengthDataType.I_DMDLDT_LENGTH_Z, 355)
'Active ou désactive la verification de la fleche finale
RdimLabelData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, FlecheFinaleY)
RdimLabelData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, FlecheFinaleZ)
'Définit la flêche due aux charges variables
RdimLabelData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Y, FlecheRelativeY)
RdimLabelData.SetDeflYZRelLimit(IRDimMembDefDeflDataType.I_DMDDDT_DEFL_Z, FlecheRelativeZ)
'Définit le deplacement des noeuds maxi
'RdimLabelData.SetDisplXYRelLimit(IRDimMembDefDispDataType.I_DMDDDT_DISP_X, depX)
'RdimLabelData.SetDisplXYRelLimit(IRDimMembDefDispDataType.I_DMDDDT_DISP_Y, depY)
'Affecte les paramètres au type de barre
'Enregistre le type de barre sous...
Robot.Project.Structure.Labels.StoreWithName(RLabel2, NomTypeBarreBois)
Message 20 of 29
Rafal.Gaweda
These parameters are implemented:
        RdimLabelData.SetDeflectionYZ I_DMDDDT_DEFL_Y, 1
        RdimLabelData.SetDeflectionYZ I_DMDDDT_DEFL_Z, 1
        RdimLabelData.CantileverMode = 1
        RdimLabelData.SetDisplacementXY I_DMDDDT_DISP_X, 1
        RdimLabelData.SetDisplacementXY I_DMDDDT_DISP_Y, 1
Rafal Gaweda
