Can Robot do a buckling analysis of a shell structure with several combinations BUT to only give the critical load with the augmentation of only one load from combination (example, a structure with self-weight and wind action, give critical load only on respect to the increase of the wind load)?
Thank you
Solved by Rafal.Gaweda. Go to Solution.
Once I had such API macro.
I will try to find it.
Update 1
Avoiding launching calculations several times - suitable for larger models.
I have tried the Macro but it doesn't seem to work.
My intention was to keep one load case constant (say the selfweight) and determine the buckling factor for a live load case. The Macro seems to give the buckling factor for both. For example;
1.0 x Basic case + 1.0 x Case for increment ----- say buckling factor of 15 (the Macro considers 15 time the Basic case + 15 times the Case for increment).
Thanks.
The purpopse of this macro is:
"....BUT to only give the critical load with the augmentation of only one load from combination"
Hi Rafal,
I thought the intention is to;
Cheers.
