API Buckilng
11 REPLIES 11
Message 1 of 12
437 Views, 11 Replies
API Buckilng
How can I get BuckLengthY ?
I've tried this but it crash on gRobotBarFlambement.EigenVector :
                Current.ResultatsRobotFlambement = New List(Of ResultatRobotFlambement)
                Dim TousCas As RobotOM.IRobotCaseCollection = gProjet.Structure.Cases.GetAll
                For Each iBarre As Integer In Current.Barres
                    If gProjet.Structure.Bars.Exist(iBarre) Then
                        Dim Barre As RobotBar = gProjet.Structure.Bars.Get(iBarre)
                        Dim iStart As Integer = Barre.StartNode
                        Dim iFin As Integer = Barre.EndNode
                        If iStart > iFin Then
                            iStart = Barre.EndNode
                            iFin = Barre.StartNode
                        End If
                        For iNoeud As Integer = iStart To iFin
                            If gProjet.Structure.Nodes.Exist(iNoeud) Then
                                'Dim N As RobotOM.IRobotNode = gProjet.Structure.Nodes.Get(iNoeud)
                                For iCas As Integer = 1 To TousCas.Count
                                    Dim Cas As RobotOM.IRobotCase = CType(TousCas.Get(iCas), RobotOM.IRobotCase)
                                    Dim Fla As RobotBarBucklingData = gRobotBarFlambement.EigenVector(iNoeud, iCas, gProjet.Structure.Results.Any.Mode)
                                    Dim D As Double = Fla.BuckLengthY
                                    If D <> 0 Then
                                        Dim Res As New ResultatRobotFlambement With {.Barre = iBarre, .Noeud = iNoeud, _
                                            .Cas = Cas.Name.Trim, .LongueurFlambement = D}
                                        Current.ResultatsRobotFlambement.Add(Res)
                                    End If
                                    Fla = Nothing
                                Next
                            End If
                        Next
                        Barre = Nothing
                    End If
                Next
                TousCas = Nothing
11 REPLIES 11
Message 2 of 12
Rafal.Gaweda
Check this
Dim RBD As RobotBarBucklingData
Set RBD = Robapp.Project.Structure.Results.Bars.Buckling.EigenValue(barnum, casenum, modenum)
blenZ= RBD.BuckLengthZ
Rafal Gaweda
Message 3 of 12
in reply to: Rafal.Gaweda
thx,
I've tried it
but this crash :
how get you the modenum ?
Message 4 of 12
Rafal.Gaweda
you get   RBD
you have to specify for which bar, case, mode (barnum, casenum, modenum) you want to get RBD from Robapp.Project.Structure.Results.Bars.Buckling.EigenValue
Rafal Gaweda
Message 5 of 12
thx
that's ok
'I specify the case number like that :
dim TousCas as RobotOM.IRobotCaseCollection = MyRobotApplication.Project.Structure.Cases.GetAll
'the BucklingServer
dim BuServer as RobotBarBucklingServer = MyRobotApplication.Project.Structure.Results.Bars.Buckling
'the barre number like that :
for each iBarre as integer in Current.Barres  'All My Bars
    if MyRobotApplication.Project.Structure.Bars.Exist(iBarre)
        for iCas as integer = 1 to TousCas.Count
            'I've got a crash on getting EigenValue, when I'm using UI on robot it works fine with same project
            dim Bu as RobotBarBucklingData = BuServer.EigenValue(iBarre, iCas, 1) '1->ModeNum
        next
    end if
next
Message 6 of 12
Rafal.Gaweda
This loop
means you are trying to get buckling results for each \ all cases in project
Do you really have only \ all cases set as buckling in model?
If not, you have to check case type
Dim CaseType As Integer
    CaseType = Robapp.Project.Structure.Cases.Get(iCas).AnalizeType
    If (CaseType = I_CAT_STATIC_NONLINEAR_BUCKLING Or CaseType = I_CAT_STATIC_BUCKLING _
        Or CaseType = I_CAT_COMB_BUCKLING Or CaseType = I_CAT_COMB_NONLINEAR_BUCKLING) Then
Rafal Gaweda
Message 7 of 12
thx,
but yes I have to,
all cases are manually set to Robot from strFile
Message 8 of 12
Rafal.Gaweda
my example VBA code (all bars; all cases must be set as buckling in model)
Dim robapp As RobotApplication
Set robapp = New RobotApplication
Dim TousCas As RobotCaseCollection
Set TousCas = robapp.Project.Structure.Cases.GetAll
Dim TousBarres As RobotBarCollection
Set TousBarres = robapp.Project.Structure.Bars.GetAll
'the BucklingServer
Dim BuServer As RobotBarBucklingServer
Set BuServer = robapp.Project.Structure.Results.Bars.Buckling
For i = 1 To TousBarres.Count
        iBarre = TousBarres.Get(i).Number
        For iC = 1 To TousCas.Count
            iCas = TousCas.Get(iC).Number
            Dim Bu As RobotBarBucklingData
            Set Bu = BuServer.EigenValue(iBarre, iCas, 1) '1->ModeNum
            Ly = Bu.BuckLengthY
            Lz = Bu.BuckLengthZ
        Next iC
Next i
Rafal Gaweda
Message 9 of 12
it still crash
I've add your precedant post to test but it's not better
Dim B As Boolean
Select Case Cas.AnalizeType
Case IRobotCaseAnalizeType.I_CAT_COMB_BUCKLING
B = True
Case IRobotCaseAnalizeType.I_CAT_COMB_NONLINEAR_BUCKLING
B = True
Case IRobotCaseAnalizeType.I_CAT_STATIC_BUCKLING
B = True
Case IRobotCaseAnalizeType.I_CAT_STATIC_NONLINEAR_BUCKLING
B = True
Case Else
B = False
End Select
If B Then
Dim Fla As RobotBarBucklingData = gRobotBarFlambement.EigenValue(iBarre, iCas, 1)
end if
Message 10 of 12
maybe because I have got a disjoined structure
but it works on Robot UI
Message 11 of 12
I've tried it on Excel and it works
it's on vb.net that it crash
Excel code :
Public Sub test()
Dim gRobotApplication As RobotOM.IRobotApplication
Set gRobotApplication = New RobotOM.RobotApplication
Dim gProjet As RobotOM.IRobotProject
Set gProjet = gRobotApplication.Project
Dim gRobotBarFlambement As RobotBarBucklingServer
Set gRobotBarFlambement = gRobotApplication.Project.Structure.Results.Bars.Buckling
Set TousCas = gRobotApplication.Project.Structure.Cases.GetAll
Dim ToutesBarres As RobotBarCollection
Set ToutesBarres = gRobotApplication.Project.Structure.Bars.GetAll
Dim i As Integer
For i = 1 To ToutesBarres.Count
Dim iBarre As Integer
iBarre = ToutesBarres.Get(i).Number
If CBool(gProjet.Structure.Bars.Exist(iBarre)) Then
Set Barre = gProjet.Structure.Bars.Get(iBarre)
For j = 1 To TousCas.Count
Dim iCas As Integer
iCas = TousCas.Get(j).Number
Set Cas = TousCas.Get(iCas)
Dim B As Boolean
B = True
B = True
B = True
B = True
Case Else
B = False
End Select
If B Then
Set Fla = gRobotBarFlambement.EigenValue(iBarre, iCas, 1)
Debug.Print Fla.BuckLengthY
End If
Next
Set Barre = Nothing
End If
Next
Set TousCas = Nothing
Set gRobotBarFlambement = Nothing
End Sub
Message 12 of 12
I've found the problem
After Buckling Calcul,
Robot must be interractive to get BucklingResults
if it's not it crash
