API Bracket definition
8 REPLIES 8
Message 1 of 9
samuel.pereira
559 Views, 8 Replies
I'm trying to create a bracket and assign to a bar using Robot steel API.
It’s possible provide a complete example to "Visual Basic -Microsoft Excel" for a “Bar” type?
8 REPLIES 8
Message 2 of 9
Example
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
    Dim RBracket As RobotLabel
    Dim BracketData As RobotBarEndBracketData
    Set RBracket = RobApp.Project.Structure.Labels.Create(I_LT_BAREND_BRACKET, "Bracket")
    Set BracketData = RBracket.Data
    BracketData.Type = I_BEBT_PLATES
    BracketData.SetValue I_BEBDV_HEIGHT, 0.4, 0
    BracketData.SetValue I_BEBDV_LENGTH, 0.6, 0
    BracketData.SetValue I_BEBDV_THICKNESS_1, 0.01, 0
    BracketData.SetValue I_BEBDV_THICKNESS_2, 0.02, 0
    BracketData.SetValue I_BEBDV_WIDTH, 0.3, 0
    RobApp.Project.Structure.Labels.Store RBracket
    bar_number = 1
    Dim RBar As RobotBar
    Set RBar = RobApp.Project.Structure.Bars.Get(bar_number)
    Dim BarE As RobotBarEnd
    Set BarE = RBar.Start
    BarE.SetLabel I_LT_BAREND_BRACKET, "Bracket"
    Set BarE = RBar.End
Rafal Gaweda
Message 3 of 9
Thank you!
Message 4 of 9
1090174
in reply to: Rafal.Gaweda
Hi Rafal,
how can i create a bracket with same section of Beam? i just need define Height and Lenght.
I already change your preview code for BracketData.Type = I_BEBT_SECTION but know i dont know what i have to do.
regards
Message 5 of 9
Rafal.Gaweda
in reply to: 1090174
Set H and L ; enough
Rafal Gaweda
Message 6 of 9
1090174
I already did it, thank you!
I have another question, can i select nodes by coordinate?
regards
Message 7 of 9
Rafal.Gaweda
Yes, of course.
Write your method \ function doing that.
Check this also:
http://forums.autodesk.com/t5/robot-structural-analysis/api-c-sharp/m-p/3233830/highlight/true#M1467
Rafal Gaweda
Message 8 of 9
1090174
Thi code is for select a node (in this case node 1)
Dim sel_node As RobotSelection
Set sel_node = Robapp.Project.Structure.Selections.Get(I_OT_NODE)
sel_node.FromText (1)
but my question is if there any option for select a node by coordinates, for example select a node with coordinates (1,1,1)
regards
Message 9 of 9
Rafal.Gaweda
There is no.
You have to write it by your own.
Rafal Gaweda
