Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
API: Bars Under The Curtain Walls
Romanich
Mentor Mentor
Romanich
Hello there,
We already know, that the panels with a calculation model curtain wall must be placed only on the panel's or opening's edge. We should create dummy bar on the bottom of the curtain wall to take one to the calculation model in any other case. If model has a lot of curtain walls (for example model from Revit) this is a problem.
To solve this issue, I have written small add-on: just select necessary panels in Robot and press Create button. It has some limitations: panels should have object type Contour with 4 vertices and 2 vertices at the bottom must have similar Z coordinates. Only panels 1 and 2 will be taken into account:
When process has finished, created bars automatically highlighted in the model. Moreover, user will obtain the list with numbers of panels which was not taken into account.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Rafal.Gaweda
Autodesk Support
Autodesk Support
Nice, added to list of our API addins
Rafal Gaweda
