Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
API apply loads on nodes
2 REPLIES 2
AbelSV78
928 Views, 2 Replies
From VB.net, I have a Robot model with bars, nodes and loads cases that I have created.
I can't find the way to apply forces on nodes. Could you indicate me the variable for this and how to use it in VB.net?
Thank you in advance, regards
2 REPLIES 2
rsousa_
in reply to: AbelSV78
See the tutorial, You can learn a lot there:
'Generate new load case.
   Dim cas As IRobotSimpleCase
Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, _
"Case_1", I_CN_EXPLOATATION, I_CAT_STATIC_LINEAR)
 '  Define load record types.
cas.Records.New I_LRT_NODE_FORCE
cas.Records.New I_LRT_BAR_UNIFORM
  ' Get the first created load record
   Dim rec As IRobotLoadRecord
Set rec = cas.Records.Get(1)
   'Define the list of objects to which load will be applied.
rec.Objects.FromText "1 2"
   'Definie the operation direction and load value.
rec.SetValue I_NFRV_FX, 50000
   'Define ALFA angle at which concentrated force acts in the structure node.
rec.SetValue I_NFRV_ALPHA, 0.52
   'Get the second created load record.
   Set rec = cas.Records.Get(2)
rec.Objects.FromText "2do4"
   'Define load direction and value.
rec.SetValue I_BURV_PZ, -110000
   'Set auxilliary load parameters.
rec.SetValue I_BURV_LOCAL, True
rec.SetValue I_BURV_PROJECTION, True
AbelSV78
in reply to: rsousa_
Thank you so much, I got it:
cas = robapp.Project.Structure.Cases.Get(2)
cas.Records.[New](RobotOM.IRobotLoadRecordType.I_LRT_NODE_FORCE)
Dim rec As RobotOM.IRobotLoadRecord
rec.Objects.FromText("1 2")
rec.SetValue(RobotOM.IRobotNodeForceRecordValues.I_NFRV_FZ, -55000)
Regards...
