(API) Addin: Walls To Loads
Romanich
Mentor Mentor
Message 1 of 9
Romanich
This addin will create loads from the selected walls.
Known limitations:
only rectangular walls with the object type Contour will be converted
- openings are not taken into account
- if number and name of the load case is empty, load case Walls with number 99 will be created
it is necessary to save/close/open the model after adding/modifications and start the addin to set object numbers in loads table (the reason is small bug in API)
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Replies (8)
Message 2 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Cool. Added to our list of addins
Rafal Gaweda
Message 3 of 9
nguyen_thang_nhat_quang
Hi Admin
Ii is very useful for me, But I am understanding how to use it?, Can you take short video, Please!
Thank you
Fan Robot Structural Analyse!
Message 4 of 9
Romanich
Xin chào,
https://youtu.be/RSv3MVzyumA
Message 5 of 9
MHDCACO
Hello, is it working for RSA 2024?
Message 6 of 9
Romanich
Hi @MHDCACO,
It should work.
Message 7 of 9
MHDCACO
I have transfered Partiton Wall from Revit to robot and when i use your application it just create a polyline. IWhat can be the issue?
Message 8 of 9
Romanich
Technically the linear load should be assigned to polyline. Please check if the correct material is assigned to the partition wall.
Message 9 of 9
MHDCACO
Yes It was the material. I've changed it but i notice sometime it works sometimes not.
