Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) Addin: Walls To Loads
8 REPLIES 8
Message 1 of 9
Romanich
2876 Views, 8 Replies
This addin will create loads from the selected walls.
Known limitations:
only rectangular walls with the object type Contour will be converted
- openings are not taken into account
- if number and name of the load case is empty, load case Walls with number 99 will be created
it is necessary to save/close/open the model after adding/modifications and start the addin to set object numbers in loads table (the reason is small bug in API)
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Tags (4)
8 REPLIES 8
Message 2 of 9
Rafal.Gaweda
in reply to: Romanich
Cool. Added to our list of addins
Rafal Gaweda
Message 3 of 9
Hi Admin
Ii is very useful for me, But I am understanding how to use it?, Can you take short video, Please!
Thank you
Fan Robot Structural Analyse!
Message 4 of 9
Xin chào,
https://youtu.be/RSv3MVzyumA
Roman Zhelezniak
Message 5 of 9
MHDCACO
Hello, is it working for RSA 2024?
Message 6 of 9
Romanich
in reply to: MHDCACO
Hi @MHDCACO,
It should work.
Roman Zhelezniak
Message 7 of 9
MHDCACO
I have transfered Partiton Wall from Revit to robot and when i use your application it just create a polyline. IWhat can be the issue?
Message 8 of 9
Romanich
Technically the linear load should be assigned to polyline. Please check if the correct material is assigned to the partition wall.
Roman Zhelezniak
Message 9 of 9
MHDCACO
Yes It was the material. I've changed it but i notice sometime it works sometimes not.
