Solved by Rafal.Gaweda. Go to Solution.
Hi @Rafal.Gaweda,
Could you please add a checkbox with on / off Robot.Interactive parameter to the merge multiple bar add-in?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Hi @Rafal.Gaweda,
It seems that you have attached an old exe file, without added option. Thanks in advance.
Roman Zhelezniak
Yes, it works
Roman Zhelezniak
Hi @Rafal.Gaweda ,
I need apply "merge bars" by VBA in my code, but this addin is in C#, I can not study well the commands for merge.
On what commands is the addin based to merge bars?
Thanks a lot.
Thanks for your feedback.
In my case, this is the initial structure:
The node 149 is the endnode for bar 34 and the start node for 33 bar. The node 266 is load node in bar 34.
My purpose is change the commun node 149 to the node 266, that is to say the node 266 must be the end node for bar 34 and the start node for bar 33.
I understand the process is something like this:
Is that so?
Could you help me with a draft code, please?
Thanks a lot!!
Hi @psanchez
I am not sure if I understood You. See my video below.
((API) addin for changing one bar node onto different one )
