Analysis report
4 REPLIES 4
antoine.carimalo
488 Views, 4 Replies
Analysis report
Hi I am looking for the analysis report. Does it really exist?
When I use the "gestionaire des calculs" the report is generated automaticly.
Where can I found it if I run calculation inside my model?
4 REPLIES 4
Try Analysis > Calculations report commands.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
I have the french version so the option is accessible from "Analys" --> " note de calcul ".
But the note de calcul doesn't indicate calculation errors or warnings like "instability" "non convergence".
I would find a file or other that includes all the errors and warnings. Is it possible if I don't use external calculation with "gestionnaire des calculs" ?
No idea?
Please check: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Log-of-analysis-errors/m-p/3505326/
Artur Kosakowski
Exactly what I need once again. Thank you very much
