Hi
I have 3 notes:
1- as we studied, we have two situations analysis and design. As concerned with analysis, we have a member with a defined span, section and applied load and we checked its capacity wether it is sufficient or not. Can ARSA do it for us?
2- In the case of two perpendicular beams, the effective depth (d) of one beam will be reduced by one bar diameter. Is this condition applied to ARSA?
3- as I noted there is a linear load on edges (surface) option in ARSA. Can this be applied to model a masonry wall load? If so, should it be applied on panels or beams?
Note: for point 3: If I select a panel the linear load is available. If I select a beam this load is available too?
Assuming that the question is 'can Robot run static analysis of a model and design its elements according to the selected design code then answer is yes.
If you increase the cover for one of them it will be
If a panel models such wall than you can apply such load to its edge.
Yes, it is but you need the use one of these from the Bar tab instead.
3- as I noted there is a linear load on edges (surface) option in ARSA. Can this be applied to model a masonry wall load on a slab? If so, should it be applied on panels or beams?
For beams (bars) you should use one of Bar types of loads e.g..:
